VW Jetta MKV TDI multiple codes HELP,,,,,,
Jamaica
VW JETTA MK5 (2007) 1.9L
Hey guys I am new on here however I have an issue that is about to drive me crazy.
The car MFD failed and I bought a entire spedo cluster to replace it, thinking that since they look identical it should just plug in and work,
This triggered several codes which cleared with my VCDS took the car for a ride to clear the abs and traction codes,,
run basic settings for G85 and brake pressure sensor. ABS module basic settings.
After that try to complete the system test...
all error lights went out, so i ran a new test, and at this point it seem like every module was having issues,
here is the scan,,,,
Wednesday,27,December,2017,15:38:13:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVWZZZ1KZ7M193560 License Plate:
Mileage: 137230km-85270mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7M193560 Mileage: 137230km-85270miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 1010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 1010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 KH HW: 03G 906 021 AN
Component: R4 1,9L EDC G000AG 9245
Revision: --H07--- Serial number: VWZ7Z0G9082302
Coding: 0000078
Shop #: WSC 00066 000 00000
VCID: 6FEBA5E77E1FDE59861-803A
8 Faults Found:
005670 - Powertrain Data Bus
P1626 - 000 - Missing Message from TCU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:27:51
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 11001000
Bin. Bits: 00001000
Bin. Bits: 10000100
005763 - Powertrain Data Bus
P1683 - 000 - Implausible Message from Airbag Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:29:22
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Bin. Bits: 11001000
Torque: 156.2 Nm
Torque: 0.0 Nm
005705 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:29:35
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 11001000
Torque: 156.2 Nm
Bin. Bits: 00000000
005713 - Powertrain Data Bus
P1651 - 000 - Missing Messages - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 81
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 798 /min
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Bin. Bits: 11001000
Bin. Bits: 00101000
Bin. Bits: 00100001
005782 - Powertrain Data Bus
P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 798 /min
Speed: 4.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 11001000
Bin. Bits: 00001000
(no units): 0.0
005714 - Please check DTC Memory of Transmission Controller
P1652 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 14
Reset counter: 255
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:38:30
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001011
Bin. Bits: 11000000
Bin. Bits: 01000100
005669 - Powertrain Data Bus
P1625 - 000 - Implausible Message from TCU - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 137230 km
Time Indication: 0
Date: 2000.00.00
Time: 01:31:00
Freeze Frame:
RPM: 1638 /min
Speed: 31.0 km/h
Load: 67.5 %
Voltage: 14.14 V
Bin. Bits: 11001000
Bin. Bits: 00000000
Bin. Bits: 00000100
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 137230 km
Time Indication: 0
Date: 2000.00.00
Time: 01:31:00
Freeze Frame:
RPM: 1638 /min
Speed: 31.0 km/h
Load: 67.5 %
Voltage: 14.14 V
Bin. Bits: 11001000
Bin. Bits: 00000000
Bin. Bits: 00000100
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 N HW: 02E 927 770 AE
Component: GSG DSG 081 1306
Revision: 04508010 Serial number: 00000703290241
Coding: 0000020
VCID: 1F4B9527CE3F0ED9761-804A
12 Faults Found:
18274 - Powertrain Data Bus
P1866 - 000 - Missing Messages - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 137230 km
Time Indication: 0
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137231 km
Time Indication: 0
00653 - Selector Lever/Auto Trans Plausibility
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Reset counter: 40
Mileage: 137232 km
Time Indication: 0
18097 - Powertrain Data Bus
P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137225 km
Time Indication: 0
18262 - Powertrain Data Bus
P1854 - 000 - Hardware Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137225 km
Time Indication: 0
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137230 km
Time Indication: 0
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137225 km
Time Indication: 0
28775 - No Communication with Gear Selector Module
U0103 - 000 - - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137230 km
Time Indication: 0
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137231 km
Time Indication: 0
18261 - Powertrain Data Bus
P1853 - 000 - Implausible Message from ABS Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137225 km
Time Indication: 0
18288 - Powertrain Data Bus
P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 40
Mileage: 137231 km
Time Indication: 0
U0103 - 004 - - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 0
Mileage: 137232 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
Shop #: WSC 02366 000 00000
VCID: 73E3A9971237FAB9629-8026
8 Faults Found:
01276 - ABS Hydraulic Pump (V64)
012 - Electrical Fault in Circuit - Intermittent
01314 - Engine Control Module
00778 - Steering Angle Sensor (G85)
01317 - Control Module in Instrument Cluster (J285)
01299 - Diagnostic Interface for Data Bus (J533)
01315 - Transmission Control Module
01312 - Powertrain Data Bus
014 - Defective - Intermittent
000 - -
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 7BF381B73A67B2F93A9-802E
2 Faults Found:
01316 - ABS Control Module
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000000637801
Coding: F4010E2700041500470A00000F000000000859035C0000
Shop #: WSC 12345 123 12345
VCID: 6BD3B1F74A072279AA9-803E
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 060607 020 0501
Coding: 00038805
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 230407 020 0105
Coding: 00208933
Shop #: WSC 12345
6 Faults Found:
01497 - Bulb for Blinkers; Front Right (M7)
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.75 V
OFF
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 26
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 35
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.75 V
ON
ON
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 2K AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD16W1Y.
Coding: 0012875
VCID: 3D774FAF64F37CC944D-8068
Subsystem 1 - Serial number: 6332MSME194E2652E
Subsystem 2 - Serial number: 6342MSME187A5F3DY
Subsystem 3 - Serial number: 6351HSME0D2D33001
Subsystem 4 - Serial number: 6361HSME0D384E15G
2 Faults Found:
014 - Defective - Intermittent - MIL ON
004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 636 0070
Coding: 0010041
VCID: 0009F65B5381D1216FB-8055
2 Faults Found:
00883 - Ignition Switch (D) Terminal S
00002 - Transmission Control Unit
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 963 B HW: 1K0 920 963 B
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0G9082302
Coding: 0019103
Shop #: WSC 00011 888 96745
VCID: 2B5371F78A87E279EA9-807E
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 63
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:27:51
Freeze Frame:
Fault Priority: 2
Fault Frequency: 62
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:29:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 86
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:29:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:29:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 138
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:31:14
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 280407F1001008
Coding: 3F3F034007001003
VCID: 2F6B65E7BE9F9E59C61-807A
8 Faults Found:
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 149
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:30:24
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 11
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:32:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 60
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:27:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 55
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:28:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:32:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 67
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:29:09
Freeze Frame:
Fault Priority: 2
Fault Frequency: 45
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:29:09
Freeze Frame:
Fault Priority: 1
Fault Frequency: 12
Reset counter: 241
Mileage: 137225 km
Time Indication: 0
Date: 2000.00.00
Time: 00:32:02
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1610
No fault code found.
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1134
Revision: 32008001 Serial number: 00000078178512
Coding: 0000692
VCID: 3B7341B77AE772F97A9-806E
2 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 137218 km
Time Indication: 0
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 137223 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 3567578F5CC3A4898CD-8060
2 Faults Found:
Freeze Frame:
Mileage: 137210 km
Temperature: 59.0°C
Voltage: 13.70 V
Voltage: 13.50 V
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Mileage: 137210 km
Temperature: 59.0°C
Voltage: 7.80 V
Voltage: 7.60 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81900A000106087F2D068F0DF0085FC6D0F8A0
Shop #: WSC 00066 123 12345
VCID: 0303F9574297CA39729-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1134
Revision: 32008001 Serial number: 00000559178402
Coding: 0000692
VCID: 3C7142AB7FE975C1733-8069
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 241
Mileage: 137226 km
Time Indication: 0
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Freeze Frame:
Fault Status: 01111000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 201
Mileage: 137226 km
Time Indication: 0
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 186 T HW: 1K0 035 186 T
Component: Radio BVX 034 0046
Revision: 00034000 Serial number: VWZ1Z2G4744338
Coding: 0040400
Shop #: WSC 00066 123 00000
VCID: 377B5D8746CF56999E1-8062
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000001621724
Coding: 0000144
Address 72: Door, Rear Right
Cannot be reached
End-------------------------(Elapsed Time: 02:44)--------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 19: DTCs clearedThursday,28,December,2017,13:21:27:33490
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Coding: 0000078
1 Fault Found:
P1652 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 137239 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:37
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00001000
Bin. Bits: 00000000
Bin. Bits: 00000100
Readiness: 0 0 0 0 1
Coding: 0000020
Revision: 00H11001
Coding: 0021121
Coding: 00038805
Shop #: WSC 12345
Coding: 00208933
Shop #: WSC 12345
Coding: 0012875
Coding: 0010041
1 Fault Found:
Coding: 0019103
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 47
Reset counter: 242
Mileage: 137232 km
Time Indication: 0
Date: 2000.00.00
Time: 02:48:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 58
Reset counter: 242
Mileage: 137232 km
Time Indication: 0
Date: 2000.00.00
Time: 02:48:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 59
Reset counter: 242
Mileage: 137232 km
Time Indication: 0
Date: 2000.00.00
Time: 02:48:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 67
Reset counter: 242
Mileage: 137232 km
Time Indication: 0
Date: 2000.00.00
Time: 02:48:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 67
Reset counter: 242
Mileage: 137232 km
Time Indication: 0
Date: 2000.00.00
Time: 02:48:46
Coding: 0019103
Coding: 0000692
3 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 137230 km
Temperature: 31.0°C
Voltage: 11.90 V
Voltage: 11.70 V
000 - -
Freeze Frame:
014 - Defective - MIL ON
Freeze Frame:
Mileage: 137230 km
Temperature: 32.0°C
Voltage: 11.90 V
Voltage: 11.70 V
Coding: 0000692
Coding: 0040400
1 Fault Found:
000 - -
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000001625519
Coding: 0000144
VCID: 3E7548A369F567D15D7-806B
End-------------------------(Elapsed Time: 02:35)--------------------------
Jamaica
observation
I also noticed that the car will start and nun normally for a few min and then the Radiator fans start to spin at super high rpm and tac (RPM) and temp gauge begins to fluctuate all at the same time and the tranny seems to disengage. the car will only drive again after 2 min or longer and the cycle begins again.
any idea
Jamaica
Anyone have any idea on how to figure out which module is bringing down the network? I noticed today if I drive with AC ON maximum cold the problem takes much longer to present itself,
Mongler98
COLORADO (SE of Denver)
HOLY FVCKING SH!T
I am not reading all that mess.
First off, delete like 99% of all that and give us the quick and dirty to whats going on, the few codes you have and then post this someplace else like a file cloud drop storage and post a link to it. And i get my ars chewed out for large picture uploads. LOL
