Vw jetta 19tdi 2006 failing flywheel
Lysander
Malta
Vw jetta 19 tdi mk5
Hello guys im new here and would like to ask you this:
Recently my flywheel has been going bad and my local mechanic told me clutch and flywheel has to be replaced. All symptoms of bad flywheel example rattling noise, vibration on clutch pedal when pressing it a bit etc and rattling noise on low revs while accelarating. 2 days later check engine light came on.
my question is :did the check engine light turn on because of the flywheel failing? As i havent scanned the car yet . TIA
**Not driving it since it came on.
Mozambiquer
Versailles Missouri
Check engine light and flywheel are likely not related. Read the codes and see what that is.
