I have a VW Golf MK7 Gt Edition 2016, had engine management light come on these three fault codes come on
08806 - Sensor for internal pressure of cylinder 3:Implausible signal
08817 - Sensor for internal pressure of cylinder 3: Short circuit to ground (GND)
08825 - Sensor for internal pressure of cylinder 3:
Implausible signal
I have changed all the glow plugs aswell as the pressure sensor one in glow plug 3 however the light came back on it was a original part from Vw , I then changed the cyclinder glow plug again as I assumed it was a faulty part and got this one from tps however the fault codes have appeared again.
Any advice could it be the wiring and any ideas on how to check this ?
Implausible signal
