Hey everyone!
I have a VW Golf Mk5 with the 1.9 PD TDI BRU 90 HP engine, and it's been giving me a really strange problem. After driving 400–500 km (though it can be completely random — once it happened after just 40 km), the engine suddenly shuts off without any warning. No stuttering or rough running — it just dies smoothly while I'm downshifting, and then it won't start again.
The only modification is that the EGR is turned off.
It used to start again with brake cleaner, but now even that doesn’t help anymore.
Pretty much everything has been replaced on the car:
At this point, I’m totally lost.
What else should I check?
Thanks in advance for any ideas!
Code:
- Wiring harness inspected
- Relays replaced
- Fuses are OK
- ECU is brand new and reprogrammed, and shows no meaningful error codes
- Timing components, tandem pump, crankshaft position sensor, camshaft sensor — all replaced
- Fuel system parts that could have caused this were swapped
- Timing is set, torsion value is 0.0
Code:
Code:
Sunday,20,April,2025,17:14:15:59248
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 23.11.0.0
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ5W101375 License Plate:
Mileage: 407460km-253183mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ5W101375 Mileage: 407460km-253183miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 FS HW: 028 101 195 5
Component: R4 1,9L EDC G000SG 6124
Revision: 12345678 Serial number: VWZ7Z0D0704231
Coding: 0000071
Shop #: WSC 01286 386 08256
VCID: 79F932A0303E225984-802C
VINID: 9E69EAAAA05BA859C10010C714E0D5B020
1 Fault Found:
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Freeze Frame:
RPM: 882 /min
Torque: 58.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 1.0
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.clb
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021121
Shop #: WSC 01392 785 00200
VCID: 3A7BEDAC75B8E941CD-806E
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 CR
Component: Climatic PQ35 081 0404
Shop #: WSC 00000 000 00000
VCID: 76E3399C01204D21E9-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00H30000 Serial number: 00000001052713
Coding: 08890F0600041800001400001400000000
VCID: 3F8D9CB86E9ACC69FA-806A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
1 Fault Found:
01064 - Terminal 58d; Interior Dimming
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: 01 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0KY8V-
Coding: 0012337
Shop #: WSC 01372 785 00200
VCID: 3169CA80A8CE2A197C-8064
Subsystem 1 - Serial number: 6332MSME0D736E05
Subsystem 2 - Serial number: 6342MSME766E1E05
Subsystem 3 - Serial number: 6351HSME20113804
Subsystem 4 - Serial number: 6361HSME42453B04
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 HW: 1K0 953 549
Component: Lenksäulenmodul 500 0030
Coding: 0000002
VCID: 6FED0CF87E7A7CE92A-803A
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 851 H
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0003103
Shop #: WSC 80093 222 69422
VCID: 2D51D6F0B4F64EF958-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 27001049270258
Coding: 2D3F0B40070002
VCID: 295922E0801E52D9B4-807C
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 9
Mileage: 407469 km
Time Indication: 0
Date: 2000.00.00
Time: 03:01:35
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 9
Mileage: 407469 km
Time Indication: 0
Date: 2000.00.00
Time: 03:01:40
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0716
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0147
Coding: 0000052
VCID: 306FCF84A3C4231173-8064
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 G
Component: EPS_ZFLS Kl.2 1401
VCID: 2F6DCCF8BEFA3CE96A-807A
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80C802087F2D8404084F01E010
Shop #: WSC 00046 412 819200
VCID: 7BF528A83A02104996-802E
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 01:37)--------------------------
Address 01: Engine (03G 906 016 FS)
17:17:12
819 /min Engine Speed (G28)
7.4 mg/str Injection Quantity
6.6°KW Injection Duration (specified)
0.0 % Accel. Pedal Pos. Sensor 1 (G79)
240.0 mg/str Exhaust Gas Recirculat. (spec.)
370.0 mg/str Exhaust Gas Recirculat. (actual)
96.4 % Exhaust Gas Recirc. Duty Cycle
13.5 mg/str Start Injection Quantity
48.0 Start Synchronisation
380.0 mg/str Mass Air Flow (actual)
989.4 mbar Boost Pressure (actual)
38.7°C Coolant Temperature (G62)
17:17:13
7.1°KW Injection Duration (specified)
360.0 mg/str Exhaust Gas Recirculat. (actual)
375.0 mg/str Mass Air Flow (actual)
