VW Drive Easy offered by Burlington VW
Status
Not open for further replies.
3193
Requiescat In Pace
Burlington, NJ {35 minutes from Phila Int"l
all the TDI's on the lot
Newly revised as of Jan 3rd, 2014
Here are the numbers for the all new 2012, and 2013, and 2014 VW Passat TDI's
Chris here from Burlington VW in Burlington, NJ.
The VW Drive Easy extended service contracts have changed as of Jan 01,2008
They have now combined the new car extension w/ the used car extension and
have come up w/ one main plan.
Now the time starts the day you sign up and the miles you choose are on top
of what you allready have!
They still have the same verbage in the new contract as far as coverages
that will be explained here:
> Allthough I am open to all coverages, I would reccomend the Platinum
> coverage as it is an exclusionary warranty vs an inclusiuonary warranty!
> These quotes are w/ a std $100 deductible.
> Should you want a $0 deductible, please add an additional $230-$517
> depending on the terms you choose!
The $100 std deductible is per visit, NOT per complaint!
> This extended service contract is valid at ANY VW dealer and the dealer
> gets
> paid thru their parts and warranty dept.
> This warranty is also valid at authorized shops and they get paid thru a
> credit card.
> You are never responsible for more then your deductible!
> If you cancel in the first 60 days, it is 100% refundable, after the 60
> days, it costs $50 and the plan will be pro-rated!
> To transfer the contract it costs $40!
> The warranties I sell are geuine VW warranties. I DO NOT deal in
> aftermarket
> warranty companies! The service contract is backed by VW and fascilitated
> thru Fidelity Warranty Services!
> Here are the coverages:
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> The Gold Plus covers all of Gold plus:
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> The Platinum covers all that and the rest of the entire car w/ the
> exception
> of this:
> brake linings,brake drums and rotors,disc brake pads,std trans clutch
> components,air bags,solar powered devices,hinges, glass, lenses,sealed
> beams,trim moldings,door handles, lock cylinders,tires, batteries, light
> bulbs,upholstery, paint,bright metal,freeze plugs,heater and radiator
> hoses,exhaust systems,shock absorbers,audio,security or other systems not
> factory installed, work such as front end alignment or wheel balancing,
> constant velocity joint boots, safety restraint systems,cellular
> phones,electronis transmitting devices{except those specifically listed
> under silver, gold, or gold plus coverage},radar detectors,appliances,near
> object avoidance systemand all oither laser radar cruise control
> components,
> vinyl and convertible tops.
Here are the quotes depending on how many miles are on your Passat TDI
Please note that this contract starts from the day you sign up and the
miles
are on top of what you allready havexxxx +
These quotes are vaild until you hit 9999 miles or the end of the year!
4yrs or 100K=$1634
5yrs or 75K=$1311
5yrs or 100K=$1731
6yrs or 60K=$1182
6yrs or 72K=$1401
6yrs or 85K=$1509
6yrs or 100K=$1902
7yrs or 70K=$1484
7yrs or 100K=$1969
If you want the 4yrs or 100K Powertrain Only
$980
Valid up to 24999 miles
This would carry you to 124999 miles total
4yrs or 48K=$1434
4yrs or 60K=$1702
4yrs or 100K=$2068
5yrs or 60K=$1791
5yrs or 75K=$2030
5yrs or 100K=$2355
6yrs or 60K=$1860
6yrs or 72K=$1964
6yrs or 85K=$2418
6yrs or 100K=$3124
7yrs or 100K=$3406+
Up to 34999 miles
3yrs or 36k =$1564
4yrs or 48k =$1915
4yrs or 60k =$2127
5yrs or 60k =$2187
5yrs or 75k =$2555
6yrs or 60k =$2310
6yrs or 72k =$2572
Chris
Chris
Chris Farnham
609-850-0244
3193
Requiescat In Pace
Here are the Touareg TDI's pricing
Revised as of Jan 03, 2014
These rates for Touaregs!
Just a note. These rates for 2011 and 2012, and 2013 and 2014 Touareg's!
> gets
> credit card.
> aftermarket
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> exception
> of this:
> components,
Here are the quotes depending on how many miles are on your Touareg
miles
4yrs or 100K=$1460
5yrs or 60K=$1125
5yrs or 75K=$1252
5yrs or 100K=$1480
6yrs or 60K=$1180
6yrs or 72K=$1281
6yrs or 85K=$1436
6yrs or 100K=$1618
7yrs or 70K=$1369
7yrs or 100K=$1680
10yrs or 10K=$1986
These quotes are valid up to 24999 miles{note, you get an additional 15K, however, the price jumps dramatically!}
4yrs or 100K=$2068
5yrs or 60K=$1791
5yrs or 75K=$2030
5yrs or 100K=$2355
6yrs or 60K=$1860
6yrs or 72K=$1964
6yrs or 85K=$2418
6yrs or 100K=$3124
7yrs or 100K=$3406
These quotes valid up to 34999 miles
3yrs or 36K=$1564
4yrs or 48K=$1915
4yrs or 60K=$2127
5yrs or 60K=$2187
5yrs or 75K=$2555
6yrs or 60K=$2310
6yrs or 72K=$2572
These quotes valid up to 44999 miles
3yrs or 36K=$1998
4yrs or 48K=$2261
4yrs or 60K=$2510
5yrs or 60K=$2579
6yrs or 60K=$2765
6yrs or 72K=$3392
Requiescat In Pace
Here are the Jetta sedans, Jetta Sportwagen, and Golf TDI's
NEW RATES EFFECTIVE Jan 03, 2014
> gets
> credit card.
> aftermarket
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> exception
> of this:
> components,
Here are the quotes depending on how many miles are on your Golf or Jetta TDI
miles
4yrs or 100K=$1516
5yrs or 60K=$1115
5yrs or 75K=$1284
6yrs or 60K=$1161
6yrs or 72K=$1368
6yrs or 85K=$1468
5yrs or 100K=$1636
6yrs or 100K=$1742
7yrs or 70K=$1427
7yrs or 100K=$1789
These quotes valid up to 24999 miles
3yrs or 36K=$1212
4yrs or 48K=$1356
4yrs or 60K=$1578
4yrs or 100K=$1877
5yrs or 60K=$1632
5yrs or 75K=$1849
5yrs or 100K=$2285
6yrs or 60K=$1710
6yrs or 72K=$1790
6yrs or 85K=$2107
6yrs or 100K=$2609
7yrs or 100K=$2901
Up to 34999 miles OR the end of the calendar year
2yrs or 24K=$1224
3yrs or 36K=$1464
4yrs or 48K=$1772
4yrs or 60K=$1928
5yrs or 60K=$1979
5yrs or 75K=$2258
6yrs or 60K=$2070
6yrs or 72K=$2297
Requiescat In Pace
I have received word from my rep that I can furnish the VW Drive Easy contract to VW's that were made for the US or Canada.
This should open up an avenue for our fellow club members to the north.
Thank You all again for the consideration.
Chris
seth1065
NJ
2011 JSW with DSG, Panoroof, rear air bags and the always fun velcro blocks, Blue with beige int
Chris,
I assume the dreaded hppf would be covered by one of this plans, JSW , would that be a correct assumption
3193
Requiescat In Pace
Chris,
Hey there! Great to hear from you. Yes, the high pressure fuel pump is a covered item under the Platinum Plan.
On a personal note, please do not forget I have a few bucks reserved for you on that service issue a couple years back!
Chris
DieselRacer
banned
AZ-NV
BMW Advanced Diesel...2011 BMW 335d
Just wanted to say if tour going to buy a TDI travel a little and see Chris, I needed a 2010 owners manual for my TDI CUP Edition that was bought from Chris in PA and delivered to NV, talk about service, originally the car did not have the manual but with a quick PM on here one was sent to me with all the contents and a manual book holder VW, if and when I ever buy another TDI new I will buy from Chris and have the car shipped to
AZ, thanks again...:):):D;):cool:
mplatt911
NY
2010 TDI cup
Can I get warranty on a 2010 cup edition that is still a certified car with 54k miles. I am heading to Hershey in two weeks and would love to stop by. My son wants a tdi. I am either selling him ours and getting a passat sel tdi or buying one for him.
Requiescat In Pace
In order for me to put a contract on your Touareg due to the fact that it is out of its factory warranty is to have you take it to your local VW dealer and get me a clean bill of health on it stated on their VW invoice
Here are the quotes
> gets
> credit card.
> aftermarket
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> exception
> of this:
> components,
Here are the quotes depending on how many miles are on your Jetta TDI
miles
are on top of what you allready have 54xxx +
1yr or 12K==$1385
2yrs or 24K=$1678
3yrs or 36K=$2056
4yrs or 48K=$2469
4yrs or 60K=$2771
5yrs or 60K=$2929
Chris
Cobradoctor
New Jersey
2013 Jetta TDI
Drive Easy, easy deal from Chris
Hey all, just got my service plan from Chris. He is super easy to work with. His service cant be beat.
Thank you, Chris.
3193
Requiescat In Pace
does the platinum warranty cover the adblue system in the 2011-12 Touaregs, or is this considered part of the excluded exhaust system?
I am sorry for the delay. I called into the warranty company techs and the AdBlue system is NOT covered under warranty.
They consider it a feature tied into the exhaust system and other then an O2 sensor, the exhauust is not a covered item.
Chris
WNY PAT
Near Buffalo NY
Hey Chris. Do you know about coverage for the failure prone turbo in the Passats? I know one guy is going through this now and they are making him sign off each step of the way to determine if the repair will be covered. Is this standard procedure with these warranties? It seems like if a covered part fails, why would VW make a customer sign off each step of the way?
3193
Requiescat In Pace
The warranty companies, even VW factory will do these steps by steps with either the client or the tech when it comes to something that may be new or something that has not really failed before.
In my experience{which is very limited on the service end vs the sales end}when they get one oof these rare cases, they will try and document and kind of micro manage the whole process to have it for future breakdowns or to see if it is really the fault of the car or components.
I hope I explained that the best I could for you in my opinion
Chris
Status
