AUGSX
So I got a set of VR6 axles what else do I need to swap out?
I really doubt tourag axles will fit without cutting and rewelding. What is the point, they will be weak after that.
If you need super strong, raxles are the way to go. Some big power has been put down with those.
iv snapped the inner joint in 1st gear, stock turbo stock tune....just fuel mods...Ya I'm not sure it would be worth the trouble to make them fit LOL..
I'll be running stock axles until they fail, if they do.. Honestly I think the inner joint of the TDI axle is more robust than the VR6, not sure about the shaft itself, but I haven't broken either at this point.. I'm sure a pair of slicks can change that..
