andy2 said:
I'm also interested in an upgrade for my mk3 as well.I would like to upgrade to vr6 axles or somthing but don't realy want to swap brakes and everything. Can the vr6 hub and/or wheel bearing be modded to fit the smaller system?
Which is why I asked if the axle shaft broke, or if the C/V and flange or hub drive broke.
I believe the axle shafts are the same between the VR6 and the four cylinder cars, that the differences are in the C/V and flanges.
If that is indeed the case, then the installation of the 4 cylinder C/V and hub splined drive on a "VR6" axle will be no different than a four cylinder axle assembly.
If the o.p.'s axle shaft broke with the 4 cylinder assembly, the shaft would have broken had it been the identical VR6 shaft.
If his C/V or axle assembly end had been the point of failure, then retaining of the 4 cylinder C/V and end (to permit retaining the four bolt hub and brakes) would still be using the same item that had failed.
It is my understanding that the VR6 axle swap is to obtain the bigger diameter brakes, and that axle durability was not a consideration, because most of the axle components are the same.
