jimbote
Certified Volkswagen Nut
Had this VL on the shelf for a few years and finally ready to adapt it to my truck. How have you guys dealt with the lack of a stop screw boss? Do you shorten the lever? thanks!
looks good and good idea... i'm.pretty sure my bv43 has the stop screw mounted to the actuator bracket...thanks!I attached stop screw boss to actuator bracket. I also shortened the lever.
cast steel housing? or iron?I welded a small tab on which I drilled and tapped the genuine stop screw from a gt1749v turbocharger...works well !
