meerschm
- Joined
- Apr 18, 2009
- Location
- Fairfax county VA
- TDI
- 2009 Jetta wagon DSG 08/08 205k buyback 1/8/18; replaced with 2017 Golf Wagon 4mo 1.8l CXBB
I have a 2010 Golf TDI and I got my 60000 mile sevice and the 23o6 update just before we went on vacation. I haven't done hand calculations of my MPG since the 23o6 update, but what I have seen is a check engine light on our vacation (800 miles each way from Indianapolis to NC) which was diagnosed as a ERG failure which caused a DPF failure. Both the EGR filter and DPF were replaced at no cost to me (federal 8/80000 warranty).
Since the repair, in mostly city driving the car has done 5 regeneration cycles in 450 miles. That is about 5 times more often than it did before the repair I'm sure that that is affecting my MPG, but even more concerning is the increase in particulate production, and how quickly this will ruin the DPF again.
I was already considering giving up on TDI's even though every vehicle I've ever owned is a VW diesel from a 1988 Jetta diesel to my current 2010 Golf. With the diminished return on MPG vs the gas Golf, higher fuel prices, and possible reliability issues with the TDI, now it is almost a certainty.
the egr does not kill the DPF, it is the other way around.
a cracked DPF lets soot out that clogs the low pressure EGR filter.
likely that one aspect of the software fix you have is to run active regeneration on the DPF more often. this means regenerate before soot builds up too much. this should make the DPF last longer.
You could be better off than you think.
