r11
worst outcome would be this proving that diesel can't be tamed to comply with EPA in US o A. In other words, diesel's inherent higher energy simply can't be extracted wo paying with higher emissions. or much much higher cost.
If VW can't do it, no one will even try. Mazda's Skyactive lo-compression diesel engine specifically looked to control NoX. And where is it ?
For us personally options range from bad to worse.
Rest assured they will make it so that simply driving your car within 100 miles of dealership will flash the ECU.
lil flag at inspections - "VW tdi must have this sticker to pass" etc. early adopters are now 2 years away from inspections.
Driving with EGR wide open at all times will destroy what our engines love the most - which is to run hot. Torque will be gone. Soot will kill the DPF.
Spraying urea at 2x the normal rate is probably the least expensive way to go. but I am not sure SCR can deal with required NoX reduction, no matter the amt of urea that goes in.
