Hose #3 follows the plastic intake piping down to the turbocharger and gets plugged into the bottom of the VNT actuator. If you put a golf tee into it and plug it then you will get very little boost (low power).Hey guys,
Sorry to be a noob, but thanks for the awesome diagrams. I have one question. I just did the EGR delete and on the Diagram im confused on where to put the vactuam hose for #3 on the diagram. I dont know where that vacuum hose goes to. All help is appreciated and thanks in advance.
Another member of the Sewcyetty Four Kreaytive spelling…Hey guys,
lol, that's great for you but I still don't have an answer.....
make sure the two hoses on the automatic shut off valve are in the correct order.Ok I had to replace my Turbo. About 3 sec. after first start up ASV valve went shut. I removed the wire from the n239 valve for a temporary fix so I could drive the car. Long term though I would like to get it fixed. with engine running If I plug the wires back on the N239 the ASV goes shut and kills the engine. This makes me think the N239 is working. But for some reason its getting a signal to close when it shouldn't. I have checked the wires back to the firewall and cant see any problem. Does anyone have any idea whats going on
Thanks in advance
Thanks for this. I was wondering how the line going to the air box played a part. I am putting an EGR/ASV deleted ALH in a Mk1 and I also can't fit the factory Mk4 airbox so I was looking for a few solutions.![]()
port sizes are approximate
excellent diagrams especially with asv and egr gone as on my motor.After using aNUT's very helpful thread to help me re-do my vacuum lines, I decided to re-make his diagrams into more complete, readable, printable, noob-friendly forms. I used his diagrams in combination with TonyJetta's labels. They're color coded so that you don't start looking at one and accidentally look at a different one next time you take a glance. I named the thread very verbosely to hopefully have this thread come up when such a topic is googled.
Here are vacuum diagrams for a stock ALH, ALH with EGR delete, and ALH with EGR and ASV delete.
Images are thumbnails. Click for full-size.
Of course it goes without saying that although these are the "shortest" paths, these are not the only options. Please let me know if I missed something or messed something up.
If you are using a 'racepipe', i.e. no ASV, then remove 'em and plug any loose hoses.Well I lose power when I remove the N239 and N18??? I have an EGR DELETE on my 02 vw jetta TDI.......
what do we plug the hoses with??If you are using a 'racepipe', i.e. no ASV, then remove 'em and plug any loose hoses.
Is this good scheme for awx/avf motors?After using aNUT's very helpful thread to help me re-do my vacuum lines, I decided to re-make his diagrams into more complete, readable, printable, noob-friendly forms. I used his diagrams in combination with TonyJetta's labels. They're color coded so that you don't start looking at one and accidentally look at a different one next time you take a glance. I named the thread very verbosely to hopefully have this thread come up when such a topic is googled.
