I'd again like to thank the user that made up those nifty diagrams for the vac lines after an EGR and ASV delete! I had been having an overboost issue for a while and had replaced all the vac lines with silicone hose to no avail, but just yesterday I completed the full removal of the EGR, EGR cooler, and ASV and re-routed my vac lines according to the diagram and my little Golf has never run so well! I was stuck in what I thought was limp mode, topping out at around 65 mph on the highway, now I can comfortably hit 90. Such a relief! Really simplified the top end of the engine bay too.
And in reference to the previous post, the ASV delete is getting rid of your anti-shudder valve. It is that plunger looking mechanism on the backside of your EGR valve body, and it's primary function is to smooth out the shutting off of your vehicle. The N18 and N239 tell the ASV to close and it cuts off the air to the intake by activating the plunger, which, in turn, closes the plate in your EGR valve body. I have no noticed a real difference with and without the ASV though, so if you are removing the EGR to put on a race pipe, there are no worries about the ASV going with it in my opinion.
