garrettp
Former Chip-Monk
well, i'll be darned... looks like i can post offer all Hi again all. for those that don't know me, that is prolly a good thing.
regardless, I am in the process of putting a VNT25 on my car and need input on the VNT actuation PSI. I will be using PSI instead of the stock vacuum system as i can control boost on my own this way. I was wondering if anyone would have input as to when the boost should open the vanes? i was thinking of 9PSI is where the vanes should start to open.
I do have a dawes device on my car now that operates my K04 turbo which seems to work quite well and throws no codes as the stock N75 valve is still hooked up electronically. I will also be throwing in a 12mm pump and i have .203's now but will go to .216's after i pay some medical bills off (pnuemonia )
the other question i have is if anyone knows if the VNT actuates at idle or when you slow down. as i understand the vanes should be open when you slow down or at idle so as to releive the turbine and also help keep the vanes free from carbon. i was thinking of installing a vacuum gauge on my stock N75 to check to see exactly what it does and when it does it (if at all of mentioned above). has anyone checked this? any input would be great.
for those that dont know me or those that do and thought i died, here is a quick run down of my JEDI...
2000 JEDI TDI (debaged save a "1.9 TDI" from Euro Audi)
281,000 miles with original clutch (thanks K04)
UPsolute Chip (custom made for me )
Up FMIC (Christmas present from Rene)
.203's (Greg Landyut install)
K04 Turbo (installed and piped by me, i am a weldor/piper now)
Wide open Exhaust
PiperX Cone filter w/ custom CAI box
customized Euro cluster w/ V1 remote display
short(est) shift kit
The K04 is great save the lag. boost does not come on until 2300rpm but then it hits 24 PSI and LOOK OUT. I put the K04 on around 175,000 and this may help to the fact that i still have my original clutch . once i get the VNT25 in i am sure i will need a new clutch but i drive pretty moderate and save the punching it for the hi-way. will also take the head off and check the piston protrusion and maybe go with the 1-hole if need be (mileage is more inportant to me so no lowering compression for more boost for me).
I also work with a guy now that makes Bio in his garage so we are going to starting making it together /off topic info.
well, that is it. good to be back(<---?)
theres other stuff but i need to go to bed.
Wide open Exhaust
