yes, increasing the arm length will allow the vanes to open a bit more. There is also a leverage ratio that the linkage system uses. For every degree the arm moves, the vanes move a greater angle..like 2 degrees, for example. I don't give an exact ratio, because I do not recall what it is. So if you can get 5 more degress on arm, it will mean a much bigger difference to vane angle. Rotating the bearing cartriage relative to the exhaust housing also plays with the range that the vanes can operate, but that means removing the locator pin and you need to very carefull when messing with that option.
regarding the fueling, your EGT should give you a good idea of that situation - do you climb fast past 1400F? Do you hit over 1600F unless you let off? etc. Even better, you should be running a EMP guage, at least temporarily while getting tune/set-up right. When EMPS get in too high of a range you get boost creep. I think ultra long injection durations that some people use to maximize performance from undersized injectors tends to create much higher EMP and EGT's as well. Just something to consider. The goal is to hit the desired power level with a proper injection duration.
