Try this...
My current 99.5 Jetta Tdi has always felt dog slow and had a weird idle 'chuffle' that has been troublesome. I bought the car with 133K miles on it. I have had Oldpoopie, Whitedog, Jetpuf, and a bunch of other people try to help me troubleshoot it to no avail. We have swapped injector nozzles. We have done the hammer mod to the IP. We have adjusted IQ settings. I have tried tens of times to do "Italian tuneups." I have run every additive under the sun. I have done Arby's nozzle cleaning procedure (forgot name of additive (DP
somethingorother.))
Nothing has worked.
Well last Tuesday I decided to give the VNT actuator rod & vacuum pot a workout. The car was still cooling down from a short drive. Reaching in from above with leather gloved hand, I could only move it about 3/4", or with great effort, to about 1". It made a crushing sound, like a bunch of carbon being squished. I then put the car up on jack stands and removed the lower cover. Using my gloved thumb, I cycled the actuator rod until my arm tired, pushing as hard as I could. Each time it sounded like carbon being scrunched up between the vanes. I then started the car and tried to move the actuator but could not move it against vacuum. One more time, I got under the car and excercised it, pushing with all of my strength until my arm gave out. I had move it through full cycling at least 15 times total. Each time it got a little tiny fraction better in total movement/ease of movement.
Then I got in the car and after warming it up, drove the spank out of it...no change
Came back to the garage and added a 5X dose of Howe's Meaner Power Cleaner. Did another Italian tuneup. Still no more power
But the next day, I added some biodiesel so that the final percentage was B25. I then did another Italian tune up and could definitely tell a small increase in power. Normally, a B25 blend makes my car feel even slower than normal. The following day I did another on my way up to X-country ski around Mt. Hood with Jimswea (club member from Vancouver.) Even though we're both big guys, the car felt more powerful than if it just had had me in it.
This thing was finally starting to feel like I thought it should!
Over the weekend I continued to excercise the VNT actuator rod by hand, pushing all the way until my hand hurts...listening for those crunching sounds. I will continue to do this until I hear metal on metal sounds...exercising VNT rod by hand then Italian tuning. I am now able to win stoplight races against my neighbors cars that used to beat me (see the same cars day in and day out around where I live.)
Last night I decided to provoke the condition which reliably gave that idle chuffle: idling in first or second gear around my parking lot and into my garage...almost imperceptible! It used to almost buck under these conditions.
This has restored so much performance I am thrilled!
Next item is to lubricate the rod with some molybdenum disulfide grease.
From now on I am going to do this as a monthly preventative maintenance item, and do Italian tune ups 2X a week. Thanks to all who've gone here before.
