Drivbiwire
Zehntes Jahr der Veteran
- Joined
- Oct 13, 1998
- Location
- Boise, Idaho
- TDI
- 2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI
If you have a turbo that is jammed up and causing an Overboost code, you will need to follow the following procedure. To keep the file size to a minimum, I eliminated the removal process and kept it to strictly the repair of the turbo.
This issue is often caused by "Babying" the motor and short shifting at low rpms. People who have this issue are often the ones that have been being gentle with the motor and not following my guidelines of shifting at 2500rpm when cold and at no less than 3,000 rpm when warm.
Anyway, here is what you need to do to fix your turbo:
http://pics.tdiclub.com/data/500/Drivbiwire_VNT_repair_procedure_small.pdf
And when it is all said and done this is how your VNT actuator rod will move!
http://pics.tdiclub.com/data/500/2006_0603_175432AB.AVI
DB
DB
