boost oscillation gtb2260
im having a problem seting up the vnt on my gtb2260vk on a pd170
i had to readjust all the actuator as the stock position it was in would not fit in the engine bay as the actuator was hiting the firewall
so for intial setup i had the vnt set to full open and then set the actuator rod with no vacume to that position and locked the nuts
idle at 85.10%
but full boost vnt is droping to 12% ?
i am requesting around 27psi and my first boost logs of the current vnt rod was making 24psi and the boost is hunting see below
so after the above i set the rod 3 turns longer (pulling the rod out of the actuator?)
this then only produced 21 psi of boost and i am requesting 27psi and its still hunting for boost
so then i went back to the original position
and did around 3 turns in the other direction shorten ? mayb even lengthen
but this now produces around 30psi of boost and its not hunting as bad but the vnt is still droping down to 12% ?
as i understand it should idle around 85% and at full WOT it should be around 25-30%
so why is it that in any position i set it i am ending up with 12%vnt ?
i am doin the mapping im ok with the hybrids and stage 1 or 2 tunes but this is somthing totally new
im thinking i may have to pull some vnt out of the map ?
any advice on this please as im in deep water
Thank you
idle at 85.10%
Thank you
