Vibration in Steering at Low Speed
owr084
Northern Virginia (NoVA)
Passat GLS, 2005, Stonehenge Gray
My Passat has acquired a vibration in the steering wheel at low speeds (less than 10 mph). It feels like a metal on metal rubbing. It is present turning left or right, but not going straight. I do not have any "clunking" or loud sounds outside the car. The vibration goes away at higher speeds.
Bearings?
gdaniel
Tennessee
2005 Passat
Jack the front of your car up and put on jack stands . Reach under there and grab each drive shaft and check for any movement . Get rough with it and shake it hard . If you have a lot of play in it replace them . Do that before you listen to anyone who might say there are worn motor mounts or balance shaft issues.
