Mrrogers1
- Joined
- Jun 25, 2006
- Location
- Omaha NEEEBRASKA
- TDI
- 2011 Golf TDI 6MT, 2011 Jetta TDI DSG, 2015 Golf Sportwagen S TDI DSG
Hi! I have a buddy that we've been working on his TDI sedan with 147k on the clock, trying to figure out why his car is running so bad. Someone told him they thought it might be an injector so I looked using VCDS and the IQ was way off for cylinder 1. We replaced that injector, cleaned the plugs on the injector harness good and nothing changed.
We also noticed that the timing was pretty far off so we looked at his TB and the cam gear was at the stops which is not how it should have been when whoever did his tb job. We corrected that and still, running like poo.
I examined the cam and took a couple pics as I have done a cam job before BUT it was before the point of failing the terrible running of the car. I'm not sure if the damage we found could cause what we are seeing.
Below are links to 2 videos, one at idle and one with low sustained revs. You will see (it might be painful to watch) how bad it's running but also listen closely as I hear a squealing/whining as well.
Let me know what you guys/gals might think is wrong with this thing. Next step I was going to suggest was a UOA from Blackstone to try and possibly confirm if it's cam/cam bearing or something else seriously mechanically wrong like crank shaft bearing spun or something. (*can they even tell if its crank shaft vs cam issues from analysis??)
Here it is at idle https://youtu.be/iQ6ToDgSDyo
Here it is with low revs https://youtu.be/qSQAs34yNQE
Thanks for any and all suggestions you all can offer.
