How much additional fuel capacity does venting gives you?
What I mean is this. I own (well VWoA owns) a 2005 Jetta TDI sedan. I have been tracking mileage as well as distance I can travel on 1 tank (about 500 miles per tank). My concern is once the fuel warning light comes on. I understand that is supposed to happen with 1.5 to 2 gallons left (by my numbers I should be able to go 50 to 75 miles on reserve).
Well, within 15 miles of the warning light coming on I filled up, vented for a total of 14.516 gallons diesel. So I either have a warning light that is way off and I “got lucky”, or by venting I am able to use the full 14.5 gallon capacity PLUS an extra amount because of venting. My question is how much is that extra capacity?
I have done the searches here and see anything from no additional capacity to 2 or 3 gallons. So what is the safe number to use? Can you trust the warning light to be 2 gallons remaining regardless of whether you vented or not?
The numbers so far: 2005 (A4) Jetta Sedan, Automatic.
2100 Miles since new (4/12 delivery)
50/50 city/hwy driving
Hwy speeds tend to be on the higher side (75mph +/- but below 2500 rpm’s)
Averaging about 37mpg
PB
PB
