Fortuna Wolf
GWilli's photos are down. Anyone have another link to photos?
Nope, nor can you effectively use big rig size nozzles.Sue B said:Can you do a ventectomy on an A5 Jetta?
here ya go.oguzooz said:aight i posted this a few weeks ago and no one could answer it. it just popped back into my head when i rough started this morning.
i need to replace the glowplug fuse/ fuse box. and maybe wiring. does anyone know what the holders part number is? and what fuse it is?
thanks for your help.
Andy67 - you're not far from me. I haven't done this mod yet (but plan to), but even working the vent manually, I think I can get 655 or more on a tank, but not 49+mpg. Am I driving too aggressively, or do you do all highway driving? I'll be amazed if you're getting that mileage in the stop/go of Centerville and surrounds....Andy67 said:I got 655mi./49.88mpg on my last, pre-vented tank. I'm trying to get into the 900 club on this one after bumping up the tire pressure to 42f/38r.....
Simple... you have the PD motor, he doesn't. You should be able to get within 3-5 mpg of his figures given the same driving style. I have driven both models and it's an economy vs performance toss up which to get.360gtracer said:Andy67 - you're not far from me. I haven't done this mod yet (but plan to), but even working the vent manually, I think I can get 655 or more on a tank, but not 49+mpg. Am I driving too aggressively, or do you do all highway driving? I'll be amazed if you're getting that mileage in the stop/go of Centerville and surrounds....
I drive mostly between just north of Richmond and Fredericksburg, and usually just shy of 75mph (set the cruise at 2500rpm) - getting me usually in the 42-45 range. My wife drives the Beetle from just north of Richmond down to her office in Newport News - usually closer to 80, and about 42mpg.
I really think that the only way I could get that kind of mileage is if I'm travelling flat roads out in the midwest and only going 60mph or so. Please tell more about your driving styles/habits and how you achieve that awesome mileage!
Thanks!
Well, after reading the whole thing and wondering why 1) I already get 600+ on a tank on my car, and 2) how much farther can I go, I came to this!david_594 said:Won't work on an 06.
I did the ventectomy...successfully.psychosapper said:I just want confirmation that doing this mod will allow me to fill up as usual--i.e. I can still set the pump handle to shut off automatically when the tank is full and not worry about it overflowing...
Can anyone that has done this mod please confirm this for me?
Thanks, and I apologize for my ignorance in advance!!![]()
Thanks for the response. I'll do the mod this weekend and fill'er up!!DwightC said:I did the ventectomy...successfully.
Yes, the pump handle WILL shut off automatically and you should NOT worry about overfilling it. Here's the reason: There is enough foam created when you fill, that the foam will provide enough early warning to the pump nozzle to shut it off. Actually, what I do, is I wait till the foam disappears, then continue to pump more fuel in VERY SLOWLY until I can see the fuel in the tank's neck.
Don't worry. Do the ventecomy and you'll be glad you did. I do recommend that you fill very very slowly, if you can. THis will minimize the foaming, a little bit.
