If you read the fine print "The modification kit is not suitable for an engine with an original FAP / DPF system" - so actually not engineered for the OP's vehicle.
What they are saying in a "diplomatic" way is that to modify the engine for SVO/WVO you would need to delete the DPF. Again, I'm not suggesting anyone get that kit or delete a DPF, just linking it for illustrative purposes.
And there's also cases of people trying B100 (which stands a better chance of success than WVO) and barely going any distance before alerts triggered and things began messing up
I wouldn't assume that, B100 and SVO are totally different things. I'm pretty skeptical of peoples "problems" with B100 because most B100 (even commercial) is pretty bad and has tons of particles, water, and methanol in it. I could see a modern CR engine almost immediately throwing codes on a different fuel because the NOx sensors aren't picking up expected values, etc. but that still doesn't mean you will be stranded or have permanent mechanical damage.
There are plenty of people out there with tons of miles on B100 in common rail diesel trucks that have all the same BOSCH components as the CR TDIs.
