HateMy2012TDI
Thanks for this information. I took it in to the dealership yesterday (different dealership this time) and was told I should be, at least once a month, driving it for at least 45 minutes at 3500RPM. I told the tech this seems extreme, especially when the owner's manual says 15 minutes for 2500RPM. His response: "that manual is BS."My commute was 14 miles each way for the first 4 years of ownership.... no plugged DPF. I monitor EGT's and never interrupt regens in progress. My VCDS is worth every penny for many different reasons, none of which involve trying to manipulate the regen process.
Wife has driven MKVI TDI for 9 years with shorter commute... no plugged DPF. I taught her to monitor rpm when idling in park. 800 rpm means no regen in progress, 1000 rpm means active regen and time to continue driving until complete. She loves to hate her TDI when the regen starts just as she's pulling in the driveway, but knows that interrupting can lead to problems with the emissions components.
As others have suggested, you obviously have chronic issues that lead to your repeated DPF problems. Armchair diagnosis is blame your driving habits/short commute. I doubt that is the cause, even though it may contribute.
Easy solution is to delete, but you've already said that isn't an option.
Don't kid yourself and think that controlling the regen process with VCDS will solve your problems and make you change your username to LOVEMY2012TDI. If the root cause of your chronic plugged DPF isn't fixed, your headaches will only continue.
I've heard about monitoring the idle RPM and driving afterwards. I do have to be honest and say that I don't continue driving around a third of the time this happens. Figured my current driving habits would cover this but I was wrong.
