Mozambiquer
- Joined
- Mar 21, 2015
- Location
- Versailles Missouri
- TDI
- 1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI, 2005 VW Passat wagon TDI X3, 2001 VW golf TDI, 1980 VW rabbit pickup,
Likely that off brand tool you posted won't do it. I believe with the vcds you can turn it off on the 1z cars as well, though you'll want to leave the EGR solenoid plugged in if you do that, so it doesn't set a check engine light. That's only for off road use though.It is from a 1997 Passat Wagon
If you want it completely removed, you'll need to get your ecm tuned, and depending on which one you have, you'll need to send it off to the tuner.
