VCDS VAG-COM Locator
jerryfreak
Nor Cal
02 Jetta GLS sedan @295K, 99 Jetta sedan 275k,. 2015 tdi sedan, 105k
map not working for me - anybody in reno area got a cable i can use?
Hykojeff
West Valley City Utah
2006 Jetta TDI 1.9
Need Vagcom help from local guru
I'm having issues with 2006 VW Jetta TDI 1.9. N17, and MAP Vacuum issues. Turbo is at full vacuum (closed) upon startup. If I disconnect the N17 or MAP sensors the turn works since it is fully open. Need someone's with vagcom to scan and help me figure out what is the issue. New turbo, new N17 installed. I'm at my wits end tryouts to diagnose the problem. I'm in West Valley City Utterly and really need help.
WalkingDrunken
Earth
NONE
How do I remove myself from this list and how does someone else get added to it? I sold my vagcom to someone locally.
Tankthecarman
United States
2001 Jetta ALH TDI 5spd
VAGCOM (eBay)
VCDS Lite.
Savannah, Ga
It has worked awesome to dial in my HPFP after head seal replacement. Definitely willing to help people in the AO.
vwxyzero
Los Angeles, CA
'96 TDI Passat Sedan, '96 TDI Passat Wagon, & Jetta Sedan, '83 Turbodiesel (IDI)
Anyone in northwest Indiana? The google maps listing is not current.
Did you read the first half a dozen posts? Go to the top of this thread, and follow what maybe the second or third post says.
Sent from my Moto G (4) using Tapatalk
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Lo and behold, there are a couple up there.
If you still can't find one, try local VW car groups, the gas cars use the same device.
unsung
NWI
Passat, Jetta
No, never thought of reading.
I’ve attempted to contact three that were in drive distance, no replies.
mr.loops
Kelowna
2002 jetta, 2003 Bora 1.8T
Update me again,please
CAN-BUS USB
Kelowna British Columbia
jpg_jetta
Chattanooga, TN
2001 MK4 Jetta
Anyone near Martinsville, VA
Looking for VCDS near here. Brother lives up here and I fear the shop is giving bad info.
Jeff
Freeroamer
California
2015 Golf TDI MK7 2.0 CRUA 6MT - 138k
Need someone in the Fresno, CA area with a Rosstech.. Gotta run some ABS test and check some brake issues.
