blueboy7
Hey guys,
I need to know which measuring blocks to record for injector issues. Group 13 for one but there’s two more groups I can record. According to the fault codes the problem I’m having is #1 cylinder is cutting out due to an electrical issue. I’m assuming it’s the injector harness under the valve cover. But I want to record anything else that could potentially be an additional problem.
This has been an ongoing problem with my Jetta’s engine for quite some time. The issue seems to be RPM related and temperature related. When cold the engine misfires between 2000 and 2500 RPM. But when it’s at operating temperature it runs fine. Until today when it started miss firing it remain that way all the way to work even after the engine was hot. But when I drove home it went back to its usual quirks.
Thanks,
Blue
11-27-20 Fixed my original problem. Read it HERE.
Thanks,
Blue
