VCDS question
blueboy7
Pittsburgh Pa.
04 Jetta PD BEW 5M
Hey guys,
I need to know which measuring blocks to record for injector issues. Group 13 for one but there’s two more groups I can record. According to the fault codes the problem I’m having is #1 cylinder is cutting out due to an electrical issue. I’m assuming it’s the injector harness under the valve cover. But I want to record anything else that could potentially be an additional problem.
This has been an ongoing problem with my Jetta’s engine for quite some time. The issue seems to be RPM related and temperature related. When cold the engine misfires between 2000 and 2500 RPM. But when it’s at operating temperature it runs fine. Until today when it started miss firing it remain that way all the way to work even after the engine was hot. But when I drove home it went back to its usual quirks.
Thanks,
Blue
11-27-20 Fixed my original problem. Read it HERE.
MOGolf
underneath something
Could you post all the fault codes found?
Also, use the generic OBDII function to capture (and post here) the freeze frame data.
blueboy7
Pittsburgh Pa.
04 Jetta PD BEW 5M
I'll have to figure out how to do the OBDII
PD unit injector cylinder 1
P1260 impossible signal
P1666 electrical malfunction
Cylinder 1
P0301 misfire detected
Engine speed sensor
P0321 impossible signal
I changed the crank sensor already.
wonneber
Monroe, NY, USA
Did you get a Bosch crank sensor or from a local auto parts store?
A lot of people here say Bosch is the only way to go and I have to agree with them.
I think it was a parts store boost & air temp sensor I bought that convinced me.
The boost part was OK but the air temp was off from what the actual air temp was.
Car seemed to run funny after it was warm.
Real Bosch unit was OK and the air temp was very close to actual outside.
Car ran OK again iIrc.
This was with my 03 JSW.
For the misfire I've read the injector harness may be the cause.
blueboy7
Pittsburgh Pa.
04 Jetta PD BEW 5M
I bought it from ID Parts. Not a Bosch but it seems to be working fine so far.
Harness was the problem with misfire. I posted a link at the bottom of #1
Thanks for the help!
Blue
