BumbleBeeTJ
**not responsible if you screw up. do it at your own risk**
already done the following
-lock confirmation honk disabled
-convenience opening/closing windows
-coming home
-now the start "ding" sound is different(watch vid) dunno why or how it happened
-seat belt chime gone
-DRL disabled
open VCDS and go to Select Control Module
go to 09-Central Electronics
click on coding
click on long coding helper
PRESS PAGE UP/DOWN to see all the menues and you will see options for the auto lock, honk disable, coming home, leaving home, footwell lighting(lights up with light on @ 20% or higher brightness) and others... some options show up AFTER you have enabled the feature or disable the feature.
go to 17-instruments, follow above steps and you will see brake pad sensor and seatbelt chime options
go to 4F-Cent. Elec II, follow above steps and you will see tilt/slide option for comfort open/close as well as sunshade open/close option
thats it for now
-coming home
-DRL disabled
click on coding
thats it for now
