VCDS error code P0321: crankshaft position sensor
new/used golf 2006
sf, ca
2006 golf gls
hello.
this started with a problem getting smogged that i described here: https://forums.tdiclub.com/index.ph...m-problem-cant-pass-smog.535324/#post-5876781
possibly salient context:
  • the car runs fine.
  • no check-engine lights.
  • the smog guy said the comprehensive control was reading as "not ready." he suggested it might be because i had recently change the battery. but i drove it around, and it didn't pass in three attempts.
a kind and generous member of the forum read the codes with his VCDS yesterday and found error code P0321. (details below.)
i'm looking into replacing the crankshaft position sensor.
does that sound like the right path forward? if so, is it something that a novice mechanic who can replace simple parts outside the engine is likely to be able to tackle?
thanks for any insights you care to share!
here is the reading from the VCDS:
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 038 906 016 AG HW: 028 101 255 3
Component and/or Version: R4 1,9L EDC G000SG 7000
Software Coding: 0150031
Work Shop Code: WSC 00000 785 00200
VCID: 59EF8E69E503803270D-5184
1 Fault Found:
16705 - Engine Speed Sensor (G28)
P0321 - 000 - Implausible Signal
Freeze Frame:
RPM: 252 /min
Torque: 162.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 8.36 V
Bin. Bits: 00001100
Idle Stabilization: 0.0°KW
RPM: 21 /min
Readiness: 0 0 1 0 0
new/used golf 2006
sf, ca
2006 golf gls
i got my hands on an obd scanner today and tried to clear all the codes. the ccm still shows up as "not ready."
i checked the wiring on it (thanks for the great tip, stdoubt), and it has no obvious defects.
i'm going to order a new one on monday and replace it when it arrives.
while the job looks pretty straightforward, i welcome any advice.
many thanks, everyone!
Lex4TDI4Life
NorCal
2001 Golf-Ute TDI GLS 5spd Manual
Just a heads up, even once you clear the code, it will show as not ready for a while. There is a specific procedure for resetting readiness (you have to drive for a certain distance at certain RPMs) but I think if you just drive it long enough without the code coming back, it will show as ready. Once you replace the sensor, drive for a while and see if the readiness resets.
new/used golf 2006
sf, ca
2006 golf gls
when i took a look at the bolt holding the sensor in, i originally thought it had a hex head.
i just went in to remove it and discovered that it's a star head.
anyone happen to know what size?
Mozambiquer
Versailles Missouri
They are often a 9mm 12 point head, though maybe 10mm. A regular 12 point socket works
new/used golf 2006
sf, ca
2006 golf gls
it was indeed a 9mm 12-point bolt.
i replaced the crank shaft position sensor. then i drove it about a hundred miles. then i checked it with an obd scanner. it still says "ccm not ready."
i suppose the problem could be in the wiring harness someplace after the spot where the csp sensor plugs in. but that harness is wrapped in a corrugated plastic sheath, and i don't see any obvious signs of wear.
what would you do next in the problem-solving process?
P2B
Toronto & Muskoka, Canada
Did you clear the crankshaft position sensor code after replacing the sensor? Were any diagnostic codes set during the drive cycle?
new/used golf 2006
sf, ca
2006 golf gls
i suppose i could have performed the clear codes function with the scanner, but i didn't think to do it because it said "no codes" or something like that. (it was only when i went inside one of the menus that i discovered the message that said "ccm: not ready.")
as for the question about diagnostic codes set during the drive cycle, i don't know enough about all this to answer that question. i think the answer is no, since the scanner said "no codes." but maybe i'm misunderstanding. i don't know what the drive cycle is.
i'm sure it's frustrating to help someone with limited vocabulary and knowledge. i really appreciate your patience!
P2B
I suspect the scanner is not telling you the full story. If there really are no codes, I would expect a hundred miles would be sufficient to set readiness, but it's possible it just needs to be driven some more - perhaps to meet up with someone who has VCDS ;)
new/used golf 2006
sf, ca
2006 golf gls
i'll give that a shot.
many thanks for all of these tips!
(i've been concerned that the ongoing ccm unreadiness may be a sign of an expensive problem in the actual crank shaft.)
AndyBees
Southeast Kentucky
There is nothing about the crankshaft that could cause what you're experiencing with your engine.
I assume the BRM engine is basically the same as the ALH with respect to the Crankshaft Position Sensor.
There is a round plate (my words) at the rear of the crankshaft that has 4 notches in it. As the crankshaft rotates, the sensor picks up those blanks (notches). I suspect the sensor is magnetically operated, thus, when that blank spot rotates past the sensor a signal is generated.
In the photo below, one of the four notches can be seen on the right of the crankshaft. And, straight above and below the oil cooler you can see the wire going over to the Crankshaft Position Sensor.
Vince Waldon
Edmonton AB Canada
If one man's opinion helps you sleep better at night I'd tell you that IMHO the crankshaft is probably the most bullet-proof part of the entire engine. It happily survives missed shifts, hydrolocking, turbo runaways, dirty oil, 24:1 compression, and has no problem bending rods to its bidding. :)
I agree with the above: if you've not already done so a VAG-specific scanner may give you more of the story and give you a known good "clear all codes", you may still have a lingering issue with the crank position sensor system, or you may just need a bunch more miles of varied driving. The drive cycle required to set full readiness is a bit of a mysterious beast and can sometimes be a bit persnickety.
new/used golf 2006
sf, ca
2006 golf gls
thanks for the encouraging perspectives, vince and andy.
i'm determined to get to the bottom of this. with little time, less knowledge, and limited access to tools, it's become a saga.
thanks for the input and patience, everyone!
AndyBees
Southeast Kentucky
Sometimes it is a struggle and challenge with the knowledge and all the tools. Hang in there, You will solve the problem,
I'm somewhere in the middle trying to solve some Diagnostic Test Codes with the ALH TDI engine in my 84 Vanagon.
P2B
In many jurisdictions you can pass the emissions test with one monitor not ready provided the MIL/CEL is not illuminated. Is that not the case in CA?
new/used golf 2006
sf, ca
2006 golf gls
it seems to vary by smog station.
the state recognizes that computer problems shouldn't prevent you from passing, and they've set up a process to address this. but it's, as i mentioned, a process, so i avoided it.
if i'd gone that route at the outset it probably would have been easier than the path i've taken.
but at this point, the ccm readiness challenge has turned itself into a battle that i'm unwilling to lose.
new/used golf 2006
sf, ca
2006 golf gls
for reference, all of this started with this:
i've continued to check CCM readiness with an OBD scanner every month or so. to this day, it continues to read: "not ready."
after i changed the crankshaft position sensor, a remarkably kind member of the forum hooked his VAG-COM up to the car and saw that there were no errors. (this was the second time he'd done this. the first was to help me diagnose the crankshaft position sensor problem which may (or may not) have been causing my P0321 error.)
assumption 1: changing the crankshaft position sensor cleared the P0321 error i was getting.
when he saw that the CCM was still not ready, the member of the forum suggested that the CCM readiness problem would resolve itself within 500 miles. i've now passed that mark.
which leads me to assumption 2: there's some electronic problem somewhere else in the car.
i called the state agency that administers this stuff and asked about the possibility of having a state referee do a smog test. i was told that i won't be eligible to do that until i can document that i've spent $500 to get the CCM readiness problem fixed. (i think $500 was the figure. i may be remembering incorrectly. i told the agent that i've spent much more than that in my own time, but that doesn't matter.)
any advice?
Matt-98AHU
Gresham, OR
2001 Golf TDI, 2005 Passat wagon, 2004 Touareg V10.
Can you post which monitors specifically are not being set to "ready"? And is your car modified at all? Tune? EGR delete? Turbo actuator position sensor delete?
Matt-98AHU
Gresham, OR
The BEW is at least the same principle as the ALH. Crank sensor in the same location, but the tone wheel itself is way different. There's many more notches on a BEW/BHW crank tone wheel than there is on an ALH.
The BRM is a different animal altogether in that it doesn't have a tone wheel bolted to the rear most counterweight of the crank. Instead, they have integrated a tone wheel in with the rear main seal, and the crank sensor bolts to the rear main. This requires a special fixture and the crank lock tool for doing the timing belt to ensure the tone wheel gets aligned correctly during rear main seal replacement.
The commonrails are basically the same in this regard, as well.
new/used golf 2006
sf, ca
2006 golf gls
sorry, the only thing i'm getting from the OBD scanner is "CCM: not ready." it shows other items which all read "ready."
no modifications on the car.
new/used golf 2006
sf, ca
2006 golf gls
wow, thanks for this!
as a non-mechanic, the way i interpret it is: "take the car to a TDI mechanic."
does anyone recommend any in the bay area or in la?
Matt-98AHU
Gresham, OR
Well, it used to be me! I left California at the end of 2020, though.
I've heard decent things about Griffin Motorwerks in Berkeley, though.
The below image is straight from VW (nabbed from when I used to work at Royal Motors in SoMa ~10 years ago) on how to drive and check for each individual readiness monitor on PD engines
P2B
Shame it doesn't mention the one monitor the OP has an issue with :(
new/used golf 2006
sf, ca
2006 golf gls
thanks for adding that! i looked and was confused!
you've done a bunch of things to this car over the years: a crankshaft, tb, suspension stuff, and more!
new/used golf 2006
sf, ca
2006 golf gls
i don't have ready access to a vcds, but the last time i did, there were no errors.
i do have access to an OBD2 scanner. here's what it gives me:
MIL: OFF
MISFIRE: READY
FUEL: READY
CCM: NOT READY
CAT: N/A
HCM: N/A
EVAP: N/A
2AIR: N/A
A/C: N/A
O2S: READY
EGR: READY
i read on a bmw forum about a guy who had a CCM error due to a bad crankshaft sensor. the error continued after replacing it with an after-market sensor. he resolved it by swapping the sensor for an OEM one. i checked and mine was OEM.
also: i've tried this drive cycle with no success:
  1. The universal OBD-II drive cycle begins with a cold start. You should have coolant temperature below 50 C/122 F, and the coolant and air temperatures within 11 degrees of one another. This condition can be achieved by letting the car to sit overnight.
  2. The ignition key must not be left ON position before the cold start. Otherwise the heated oxygen sensor diagnostic may not run.
  3. Start the engine and idle the engine in drive for two and half minutes, with the A/C and rear defroster on if equipped.
  4. Turn the A/C and rear defroster off, and speed up to 90 km/h (55 mph) under moderate, constant acceleration. Hold at a steady speed for three minutes.
  5. Slow down to 30 km/h (20 mph) without braking. Do not depress the clutch if you are running with manual transmission.
  6. Speed up back to 90-100 km/h (55-60 mph) at 3/4 throttle. Hold at a steady speed for five minutes.
  7. Slow down to a stop without braking.
haven't seen a drive cycle specifically for this car though.
Matt-98AHU
Gresham, OR
The glow plug system cycles are part of the comprehensive components (CCM). I do remember having an ALH that wouldn't set CCM due to effectively needing a hammer mod, it couldn't rely on the injector smooth idle compensation numbers with the injected quantity set so low. heh.
That wouldn't apply to a PD, of course. Usually the glow plug cycles set that readiness monitor after only a couple cold start engine cycles.
But this document suggests using output diagnostic test mode with the factory scan tool/VCDS and viewing the binary to ensure that it set correctly after a couple different attempts. Just one way to help speed the process up of setting readiness, but without VCDS the data I linked to is kind of moot anyway.
new/used golf 2006
sf, ca
2006 golf gls
thanks, matt.
here's my takeaway from your post: a vcds might provide some data that might help hasten the process of readying the ccm. but said process is likely to right itself at some point.
is that anywhere near correct?
(also: i don't see a document in your most recent post. are you referring to the document in the post you made on 12/24?)
thanks, everyone, for your patience with this saga and with my limited vocabulary.
