novusB
Below is my VCDS scan, the user has already replaced the camshaft pos sensor and accelerator pos sensor. I am posting for another person with MK6 issues, they are on the TDI Club discord.
Code:
Monday,08,July,2024,09:38:42:22105
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
Mileage: 256860km-159605miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 Q HW: 03L 906 019 DA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H14--- Serial number:
Coding: 0050072
Shop #: WSC 74291 008 00000
VCID: 3C2127EE4A6EC27A4BB-8068
VINID: 0E69C370745A1D274104218424637AB2DA
5 Faults Found:
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 19
Reset counter: 255
Mileage: 256567 km
Time Indication: 0
Date: 2018.11.29
Time: 17:53:35
Freeze Frame:
RPM: 805 /min
Speed: 0.0 km/h
Voltage: 13.38 V
Temperature: 86.4°C
Idle Stabilization: -5.0°KW
RPM: 1254 /min
(no units): 48.0
001601 - Sensor Reference Voltage A
P0641 - 000 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 255
Mileage: 256560 km
Time Indication: 0
Date: 2018.11.29
Time: 21:40:01
Freeze Frame:
RPM: 184 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Temperature: 86.4°C
(no units): 0.0
Torque: 0.0 Nm
008482 - Accelerator Position Sensor (G79)
P2122 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 256760 km
Time Indication: 0
Date: 2018.11.29
Time: 15:38:45
Freeze Frame:
RPM: 874 /min
Speed: 23.0 km/h
Load: 0.0 %
Voltage: 13.60 V
Voltage: 0.760 V
Voltage: 0.380 V
Bin. Bits: 0 01 1
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 256795 km
Time Indication: 0
Date: 2018.11.29
Time: 15:12:01
Freeze Frame:
RPM: 2093 /min
Speed: 123.0 km/h
Load: 100.0 %
(no units): 2761.2
(no units): 2184.0
Lambda: 89.2 %
Lambda: 89.2 %
P0299 - 001 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 256795 km
Time Indication: 0
Date: 2018.11.29
Time: 15:12:01
Freeze Frame:
RPM: 2093 /min
Speed: 123.0 km/h
Load: 100.0 %
(no units): 2761.2
(no units): 2184.0
Lambda: 89.2 %
Lambda: 89.2 %
Readiness: 1 1 0 X X
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: B14B400C492300FC8D1102E892220042A70000
Shop #: WSC 00066 000 00000
VCID: 7BA3E4F203E00542021-802E
No fault code found.
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 Q HW: 5C0 820 047 Q
Component: J301 Klimaanlage 0103
Revision: 2000908S Serial number: 00000000366839
VCID: 2E051DA68C1220EAF5F-807A
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0257
Revision: B2066001 Serial number: 03311135110216
Coding: 3B994BBA08A94B0008382000260884C40082502E60000000300000000000
Shop #: WSC 45412 003 104857
VCID: 2F3B00A2871829E2FE9-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Serial number: --------------------
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.019 H08 0006
Serial number: WRH0001S8W$
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Serial number: 0229619
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTD0AUVX- Dataset Number: 160003v____ 0086
Coding: 00003935
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 34310FCE6EBE0A3A83B-8060
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100004BZP01
Coding: 303241
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4A19315EZZZ/
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME7F2E065FZZZF
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME541C6510ZZZN
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME7D114A10ZZZR
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME1916400FZZZU
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME7F0E400FZZZ7
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C6 920 950 E HW: 5C6 920 950 E
Component: KOMBI H07 0406
Serial number: 00000000000000
Coding: 070A01
Shop #: WSC 00066 123 00149
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2C0117AEB68E52FADBB-8078
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0257
Revision: B2066001
Coding: 102200
VCID: 70B9C3DE5AA6761AA73-8024
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0406
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: 6A8DD1B67CFA8CCAE97-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669648063
Coding: 010000
VCID: 2809EBBEA2F67EDA3F3-807C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 34310FCE623E0A3A83B-8060
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3194649
Coding: 01020000010006
VCID: 6393BC929B50DD822A1-8036
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 3
Reset counter: 31
Mileage: 256507 km
Time Indication: 0
Date: 2018.11.29
Time: 10:54:50
Freeze Frame:
Bin. Bits: 100
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 11
Mileage: 256507 km
Time Indication: 0
Date: 2018.11.29
Time: 10:54:50
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669482802 Dataset Number: 5K0035730 0001
Coding: 0A00000000010100
Shop #: WSC 01383 790 50316
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 629DB99684CAD48A217-8036
End----(Elapsed Time: 01:21, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
