VCDS at the Fest
Nash_TDI
Veteran Member -TDIClub Enthusiast
Louisville, ky
2000 Silver Jetta TDI
Anybody that is coming that knows how to use and has VCDS?
I need to adjust my MFA MPG readings, would also like to reprogram the window convience mod, and if all that important stuff can be done, maybe program a welcome message.
La Conner, WA
For the MFA MPG readings, you will need VAG Tacho. For the Windows, you will need VDS PRO.
I know that compu_85 will be bringing VDS PRO, so you can check that off your list. I don't know if anyone will have VAG Tacho or not.
Nash_TDI
Louisville, ky
Thanks for the correction! I was only partially sure I was asking for the correct stuff. Anybody with the Tacho program coming? I guess I will only have one shot at getting it correct. Should I start recording the % it is off by?
