Values
Measured another head. Value from top of valve to bottom of cam bore was 1.112, about .01 more than other head. Both heads are around 400,000 kms. Cam base circle is 2.086, and cam bore in head is 1.26. This leaves the base circle about .41 below bottom of cam bore. I took a 1" micrometer to measure the thickness of the lifter from the cam contact surface to the valve contact button. Seems most of them are about .75 with the button sprung out. The button will compress approx. .02- .025. This makes CNGVW about right for .01 preload on the lifter. Doing the math the valve tip should be 1.150 approx below the bottom of cam bore with out bearing. Best valves are 1.112. This would make me think the valves and valve seats have eroded almost .04. Any body seen this much wear? So at this point does anybody have a 1" micrometer and a stock lifter to verify the lifter is .75 thick approx. There must be some people who have ground their valves and seats, and have a installed height from the valve tip to some point on the head. I presume if you had the cam installed the lifter should be able to be pressed down to remove the play and a .01 feeler gauge or near there . Any suggestions please.
