phawkins224
03 Jetta Tdi ....valave cover leaking oil...What are the opinion of the TDI forum on this replacement part....
seriously? So how do you get oil pans off? They are glued on with sealer?Don't try sealant or it might not come off next time.
Razorblade or putty knifeseriously? So how do you get oil pans off? They are glued on with sealer?
You've got to be joking.Don't try sealant or it might not come off next time.
Nothing common 'bout sense.seriously? So how do you get oil pans off? They are glued on with sealer?
Amazing. These are available on ebay and no, it's not from Pr*the. I wish I had known about these back when I had my 01 Jetta. This might be a good option (or at least worth trying) rather than adding silicone to an existing 200K mile valve cover gasket.I bought a gasket on e-bay 25 buck s don't know if it was Chinese or what took 1 hour to remove the gasket with a demial tool the worst part then install 10000 miles later not a leak . the gaskets out there .
I like how people get all snooty and take your opinion as if you're retarded.You've got to be joking.
