Vagtacho 5.0 ECU option for MK6?
mavreix
USA
VW Golf TDI 2013
VDO New - CAN TP2.0 might work. those years are the european model years.
what are you trying to do?
Got a new key cut, but its not preprogrammed and I don't have the PIN.
Haven't tried VCDS yet but from what I've heard that will only program the remote lock/unlock function.
lemoncurd
Eastern CT
2013 CJAA GTB2266
ahh okay, if you have KESSY(push to start) a dealer will have to reprogram the keys sadly.
otherwise, try out that VDO New option i mentioned. try both if the CAN TP2.0 doesnt work. i doubt your cluster or ECU speaks UDS.. but the chance is never 0 until tried i suppose
mavreix
USA
VW Golf TDI 2013
Well the can CAN TP2.0 does actually say connected but it doesnt do anything after that other than blank out the gauge cluster til I disconnect or pull out the key. I havent tried UDS yet but I suppose I can try
