Monday,09,January,2023,17:14:15:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ2KZ8X145754 License Plate:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56
VIN: WV2ZZZ2KZ8X145754 Mileage: 234910km-145966miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
Address 01: Engine Labels: None
Part No SW: 03G 906 021 RT HW: 03G 906 021 AB
Component: R4 2,0L EDC 000SG 2120
Revision: --H07--- Serial number: VWX7Z0H23NV04O
Coding: 0000072
Shop #: WSC 00001 551 00000
VCID: 025D8A15380CEFCB45F-8056
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 35110 377 00159
VCID: 3FDB43E10B7E42236A1-806A
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 76B5E6C564C4C36B797-8022
1 Fault Found
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: None
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008295798
Coding: 01884F030004100057000000000000000008FF075C000100000000000000
Shop #: WSC 35110 377 08192
VCID: 71BFD5D90DAAE453AC5-8024
3 Faults Found
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 12
Reset counter: 208
Mileage: 232663 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
ON
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 100
Reset counter: 170
Mileage: 230813 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
01598 - Drive Battery Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 177
Mileage: 234042 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 1K0 919 475 HW: 1K0 919 475
Component: PARKHILFE 005 1104
Revision: 00005000 Serial number: 0 263 004 193
Coding: 000001
VCID: 6FBBD3A1179EF2A3BA1-803A
5 Faults Found
02070 - Rear Parking Aid Sensors
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 22
Reset counter: 170
Time Indication: 0
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 138
Mileage: 234180 km
Time Indication: 0
Date: 2000.00.00
Time: 14:15:20
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 138
Mileage: 234180 km
Time Indication: 0
Date: 2000.00.00
Time: 14:15:20
01545 - Sensor for Parking Aid; Rear Left (G203)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 138
Mileage: 234180 km
Time Indication: 0
Date: 2000.00.00
Time: 14:15:19
01548 - Sensor for Parking Aid; Rear Right (G206)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 138
Mileage: 234180 km
Time Indication: 0
Date: 2000.00.00
Time: 14:15:16
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AJ HW: 6Q0 909 605 AJ
Component: 1C AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037UR001RNW
Coding: 0012611
VCID: 7F5B03E14BFE82232A1-802A
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 752 0100
Coding: 0000012
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1T0 920 964 A HW: 1T0 920 964 A
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H23NV04O
Coding: 0016401
Shop #: WSC 00000 067 57207
VCID: 34311CCD3238917B873-8060
1 Fault Found
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 201
Mileage: 234694 km
Time Indication: 0
Date: 2000.00.00
Time: 13:21:05
Address 19: CAN Gateway Labels: Redir Fail!
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 100408F2011930
Coding: E9A01F064002027401
Shop #: WSC 35110 377 00154
VCID: 303910DDC620AD5BE3B-8064
3 Faults Found
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 200
Mileage: 234663 km
Time Indication: 0
Date: 2000.00.00
Time: 12:23:54
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 18
Mileage: 230804 km
Time Indication: 0
Date: 2000.00.00
Time: 19:20:13
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 210
Mileage: 231479 km
Time Indication: 0
Date: 2000.00.00
Time: 13:25:05
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1212
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1206
Coding: 0000560
VCID: 382928FD2E50751BABB-806C
1 Fault Found
00943 - Heated Exterior Mirror; Driver Side (Z4)
Address 44: Steering Assist Labels: None
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.140 H08 1901
VCID: 363526C52444836BB97-8062
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 818B04087F2D8405485AC61010C0
VCID: 0059801D3600FDDB53B-8054
Subsystem 5 - Part No: 2K0 951 172
Component: Innenraumueberw.009 4807
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Component: Sounder No Answer
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
3 Faults Found
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 52: Door Elect, Pass. Labels: Redir Fail!
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000560
VCID: 392F2DF9155A6C13545-806C
3 Faults Found
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
00936 - Electric Window Switch in Front Passenger Door (E107).
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 01:13, VBatt start/end: 14.3V/14.1V)-----------
