coffeehouse
does anyone have a copy they can send to me? or any other program that can pull the eeprom without desoldering so i can shut this immo off. everything i find ends up at dead links or untrustworthy downloads.
I've already got the v13 cable to read through the obd port (I know the v18 is far better and ill probably just order it) I was just hoping for the software to be able to read the eeprom without buying another cable but it won't kill me being so cheap.with mpps (v18) you can disable the immobo![]()
I just found it and this is exactly what I was looking for thankyou!I think you can use the kwtest program by gmenounos. Check the OBD Scanners forum here.
I didn't realize that. Good to know.with mpps (v18) you can disable the immobo![]()
i've been using that software for 3+ years, no problems....Does anyone know of a clean source for the MPPS software? All I see is the infected Panda disc.
I got mine from the disc tooDoes anyone know of a clean source for the MPPS software? All I see is the infected Panda disc.
My disc was broken, but @burpod emailed me the files I needed.Does anyone know of a clean source for the MPPS software? All I see is the infected Panda disc.
Could u forward me a copy also? Can't find mineMy disc was broken, but @burpod emailed me the files I needed.
I could forward that to you.
Looks like I don't have that info any more, maybe message Burpod and see if he can send what you need.Could u forward me a copy also? Can't find mine
Message me with details
