tiguando
As I recall it doesn't work if you have Xenons though.Thunderstruck said:Disabling DRL with the turn signal trick works on the Golf, I did it to mine yesterday.
http://forums.vwvortex.com/zerothread?id=4743553bruce846 said:Question, can someone direct me to the module in VAG-COM where you can change the number blinks from 3 to 5?
You have to go into 09 cent electronics or convenience ( I can't remember) and click on adaptation. You'll see a drop down bar and you need to go to comfort controls I think.jimmyv65 said:Has anyone documented the Key Fob windows down. I was doing some VAG COM updates and couldn't find that. All the documentation I found show that you can enable windows up/down from the key in the door, but not on the key fob.
If someone has details, I'd appreciate it.
Not a chance of this happening. Accidental presses yes but duplicated remote codes not very likely.bsalbrig said:I would hold off on the window down addition. I set my brothers a5 jetta to operate the sunroof and windows both open and close. I thought about things for a while and decided that it could be too easy for the remote button to be pressed in a pocket. Another problem is if I ran into someone else that had the same remote coding as my car (has happened with Fords in the past not with VW yet). I went back and disabled the roll down feature but left the roll up.
I have had it happen on two separate occasions on Fords. One was my fathers secretary's explorer to a bronco, their remotes would work for each other. The other was still with the bronco but I dont recall the other car. Their remotes have a further range than vw remotes but I would think that there are quite a few cars out there that have the same remote as yours. I dont know the workings of how the remotes operate whether it is just a rf signal or if it is sending some specific message on that frequency. Another possibility is when I am home at my parents, we have a bowl of vw keys. Someone could grab the wrong key and be rolling down my windows while looking at one of the other cars. In the household we have one 99, two 02s, one 06, one 10 and another 10 should arrive mid May (all but the 99 are TDIs). Plus at thanksgiving or christmas whichever one my parents get there are an additional 4 vws at the house as well (mothers family all TDIs).Stirer said:Not a chance of this happening. Accidental presses yes but duplicated remote codes not very likely.
What is the window trick all about?bruce846 said:Quote: Has anyone documented the Key Fob windows down.
Yup, Address 09 - Central Electronics:
Comfort Operation (via remote control) found in Adaptation. From the drop down list, choose 1 (on) and save... works just as advertised
Could you post the process to change the turn indicator from 3 to 5 through the MFI?740GLE said:Those two things can be changed in the MFI, well at least I was able to do it. I changed the others (excp blk bttns) you mentioned except for the auto lock, and ennjoy them everytime stepping in the car.
what is MFI? is that exclusive to the Jetta?740GLE said:Those two things can be changed in the MFI, well at least I was able to do it. I changed the others (excp blk bttns) you mentioned except for the auto lock, and ennjoy them everytime stepping in the car.
I don't think you can. You can only turn in on or off from there. You need VAGCOM to change the actual number of blinks.rickwol said:Can anybody explain how to change from 3 to 5 blinks in the MFI ?
