VAG-COM Measuring/Adaptation Blocks
mailman
USA - CT
99.5 Black Jetta TDI
Has anyone compiled a list of the VAG-COM measuring/adaptation block numbers along with what parameter they measure and what the nominal values should be?
MOGolf
underneath something
Go to the main page for "OBD Scanners". In the lower left corner, change "Show" to show all threads. Look at the oldest 3 in the list. There is one there for the engine.
MOGolf
Ok, I made it easier for people to find these. They are now stickies at the top of the list for the forum.
mailman
USA - CT
Perfect, MO. Thanks. Found the link to the Ross-Tech site with some info. Still looking for the "stickies" at the top of the list?
MOGolf
When you click on "OBD Scanners" from some page, such as above, you'll go to the main page of "OBD Scanners". The first threads in the list are now those reference postings. The little red pins indicate them as "stickies".
