VAG-COM Login Codes?
micasb
Porto, Portugal
Audi A3 8P 2.0 TDI
Hi guys.
I'm new to this. I live in Portugal and have an Audi A3 from 10/2003 2.0TDI 103Kw.
I'm trying to turn off my EGR valve, but I need a login code to access to chanel 03 in the engine module. Does anyone know it?
Some say I can find it on repair manual, but I haven't find codes.
Best regards.
micasb
Porto, Portugal
Audi A3 8P 2.0 TDI
Hi there.
I tried that code and it doesn't work. I think A3 8P has a different login code.
Anyone?
Thanks.
Uwe
Lansdale, PA, USA
Oh, an 8P? That means it has an EDC16 engine management system. There's no known way to adjust EGR via diagnostics on those.
-Uwe-
micasb
Porto, Portugal
Audi A3 8P 2.0 TDI
-Uwe-
Is that so?
Oh well i'll have to wait until someone finds out how to do it.
Thanks for the info.
owr084
Northern Virginia (NoVA)
Passat GLS, 2005, Stonehenge Gray
micasb said:
Is that so?
You do realize that if Uwe says there is no way to do it, there is probably a 99.999999% certainty that he is correct. After all, he is the man who developed the VAG-COM. Oh, and his last name is Ross, as in Ross-Tech, the makers of VAG-COM:rolleyes:;)
micasb
Porto, Portugal
Audi A3 8P 2.0 TDI
Really, i'm talking with a developer? LOL Didn't know as i'm new to this forum.
But still it asks a login code that i do not know. Is there any possibility that the VW/Audi knows that code?
I would like to do a log on my injectors to see the injection time, because my car usually shakes all over it. I think it's injection problem as I sometimes see smoke, not normal on new engines...
How can i do it?
Best regards.
Uwe
Lansdale, PA, USA
FWIW, I didn't say there no way to do it. I said there's no known way to do via diagnostics. ;-)
My understanding is that at least some chip-tuners can do it. Of course you can also do it mechanically, but this is almost certain to lead to an incessant check-engine light.
As far as logging injector values, post the ECU part number (shown as "VAG Number" when you access the ECU) so we can see exactly what you've got there.
-Uwe-
Dutch
Netherlands
110kW 2.0 TDI Golf model 7
If you turn off the EGR, the ECU will notice because it sees no difference in airmass via the MAF sensor when the EGR is driven.
With a 81kW AHF TDI I got a CEL when I disconnected the EGR. But when I modulated the MAF signal with EGR information, the CEL didn't show. (some electronics needed)
I'm planning to try this trick also with a 103kW BKD 2.0TDI.
pridyuk
CA
'04 jetta wagon pd-tdi, '97 jetta tdi, '98 jett tdi, '01 jetta tdi, '00 jetta tdi auto, '02 jetta tdi, and '03 golf tdi-parts.
a question to UWE you must know this :) whats the login code for the module 17 (instruments) cuz i got this canadian jetta tdi and i brought it in here into states and trying to recode from km to miles. i tried 12233 and it says its incorrect.
onehotspud
Grand Rapids, MI
2001 Jetta TDI
You don't need to login to do that. Do a RECODE on the instrument cluster. Look here. Scroll down until you see 17-Instruments: K1 -- KWP-1281 and read through that. It's the third digit in the recode. Change it from a 3 to a 2. So your recode number will probably be 0733x. x will either be a 2 or 4. Leave it the same.
djsega
Romania
Seat
Comfort log in code
Hello, i have a Seat ibiza 2006 model and i need the access code to enter the comfort section an read all the channels because it's just showing some of them. Do you have any idea? Thanks!!
Zero10
Calgary, AB
05 Golf TDI PD, Tiptronic
Andbody have the tiptronic login for an 05 golf tdi? Want to set it to sport mode but all the options are greyed out :( (since this has been dug up from the dead anyways... ;) )
feco
ireland
03 Audi A4 black
micasb said:
Hi guys.
Best regards.feco
Zippy1
Antioch
03 Jetta Wagon GLS - 133k
Maybe it is a language barrier, isn't your question EXACTLY the same as MICASB, but now you are in Ireland???
And Uwe answered the original question immediately after it was answered. Did you bother to check back for a response?
Look in the FAQ under cleaning the manifold.
The full procedure is listed along with the login.
Clarksburg ca
05 Golf
Hello all,
I have an 05' Golf PD TDI 5 speed
I also have a Ross Tech K2 VC and tried the 12233 code but it doesn't let me in.....
I apologise if someone has listed the code here but I'm unable to find it for the PD engine
Thanks in advance for the help
Here is what I think may be the ECU info...
Address 01: Engine
Protocol: KWP2000
Part No: 038 906 016 Q
Component: R4 1,9L EDC G000SG 6110
Coding: 0150031
Shop #: WSC 00001
Address 03: ABS Brakes
Protocol: KWP2000
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 00000
Address 15: Airbags
Protocol: KW1281
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0003
Coding: 12344
Shop #: WSC 00000
Address 17: Instruments
Protocol: KW1281
Part No: 1J0 920 907 E
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15232
Shop #: WSC 00000
Address 19: CAN Gateway
Protocol: KW1281
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00001
Address 25: Immobilizer
Protocol: KW1281
Part No: Bitte Adress
Component: e 17 eingeben
Address 31: Engine other
Protocol: KWP2000
Part No:
Address 33: OBD-II
Protocol: ????
Part No: OBD-II/EOBD, Protocol Keyword: $0808
Address 3F: Unknown Address: 3F
Protocol: KW1281
Part No:
Address 46: Central Conv.
Protocol: KW1281
Part No: 1C0 959 799 C
Component: 8C Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 00001
I ran the VC control module finder program to get this...
