VAG-COM Connection?
fhryder
New Brunswick, CANADA
Golf GLS TDI (tornado red)
Hi:
On my 02 Golf the socket is just to the left of the steering column, down below the plastic cover that hides the electrics. It's a unique looking socket as you can tell from the plug. If you stick your head down to the floor and look up you should find it.
Now how this translates when the steering wheel switches sides, I'm not sure. Is your fusebox on the left or right, it's probably not too far away from that.
Frank
Tdidaryl
Australia
Golf, 1996 & 2005, White
Fhryder
The fuse box in my car is under the bonnet. There may be another inside but I havent checked it out yet. Work always gets in the way.
I'll have a look though.
fhryder
On mine there's a little panel on the left side of the dash, right where the door closes.It's under there.
Only big fuses under the bonnet on top of the battery.
Frank
