Vacuum Routing Refresher
aNUT
Boulder, Colorado
'01 TT (ALH-ish), B7 Audi gasser, '05 Golf
I've been hanging out at TDIFest the last couple days and seen some really cool cars. Many of them are modified, and that's super cool, but the one common trend is that there seems to be some lack of understanding regarding what all those pesky vacuum hoses do. This is a refresher so hopefully next year, I don't see any golf 'Ts' in people's cars!
First; some basic info; here's what the ports on the vacuum solenoids do.
The solenoids in our cars look like the ones above. There is the 2 port type, and the 3 port type. In either case, the purpose of the device is to take a signal from the ECU and either allow or not allow vacuum to pass to the device.
All of them have a port for unregulated vacuum. Sometimes they're labled; sometimes they're not. The unregulated vacuum port should be attached (sometimes through a series of Ts or Ys) to the big black vacuum tube that's connected to the vacuum pump and the brake booster. These are labled VAC in my picture.
All of them have a port for regulated vacuum. Sometimes they're labled; sometimes they're not. The regulated vacuum port should be attached to whatever device the solenoid is controlling. These are labled OUT in my picture.
On the 3 port type of solenoid, the port closest to the connector is not labled. This port is the vent port. It allows air back to the device it's controlling to relieve the vacuum. This port is usually connected to the airbox. This is good, because that means it won't allow dirt to enter the solenoid or the device it's controlling. This is bad because if there's lots of vacuum in the airbox (from a clogged snow screen) the device it's controlling won't be able to vent its vacuum. If we're talking about an N75 that controls the turbo, it won't be able to open up the vanes and will cause overboost.
So here's how to route your vacuum lines; depending on your state of mods, so we don't have more hoses (and hence more potential leaks) than necessary. Also it will keep the engine bay looking cleaner.
If the car is a stock ALH it should look like this:
Now for the modified cars:
If the car is an ALH an EGR delete, we only need vacuum hoses going to the N75(Turbo), vacuum reservoir, and the N239(ASV) and should appear as below.
If the car is an ALH with a Race Pipe or a BEW with an EGR delete, we only need vacuum lines going to the N75 and vacuum reservoir and should appear as below.
The solenoids I've cut out of the diagram and routing diagram don't need hoses, (and certainly not golf Ts stuffed into them) but they may still need to be plugged into the wiring harness so the ECU doesn't throw any fault codes. Your tuner may be able to set up your file so they don't need to be plugged in, but you'll have to ask.
RamMan4x4
Raleigh, NC
'03 Jetta TDI
I used a spare bolt instead of a golf tee...but I'm still guilty. I'll be sure to fix it if I ever finish my stealth race pipe (I am currently running a DG racepipe, but I miss the smooth shutdowns from the ASV).
DaveLinger
Morgantown, WV
2001 Golf TDI
OP: Thanks a lot for making this thread, it really helped me sort out my vacuum lines in my EGR/ASV delete situation. The previous owner had it messed up big time. To help make things clearer for myself, I used the diagrams located here in combination with the diagrams you provided in the thread to make a new diagram:
If there is any interest, I can make similar diagrams for the stock and EGR-only delete examples.
jrip
Fort Worth, TX
Jetta, 2000, Blue, TOTALED, Jetta, 2002, Green
This is great. All the other diagrams, and there a lot of them, have everything numbered, but the numbers are never labeled. If you were to make another one for the stock ALH, labeled like this one, I for one, would be very grateful.:D
jrip
Fort Worth, TX
Scratch this question. I am not paying any attention to the details for sure. I have erased the question and hopefully nobody has read it. I am so embarased, and no I won't repeat it so don't ask.
Duradiesel
Gulfport, MS
2003 Jetta TDI
I have an ALH with a race pipe. So I got rid of the vacuum lines I didn't need according to the diagram. Now it's like in limp mode. I have not been able to check the codes yet but it was running fine before I did this.
KrashDH
Washington
2002 Golf
I know this is a really old thread, but I wanted to ask a couple of questions regarding the vacuum routing diagrams for those that have done a race pipe and or just the EGR delete.
I understand that you can leave the solenoid(s) not in use in the car and plugged in to the ECU, but did anyone cap the ends off to avoid getting debris in there?
Also, when you do either the delete and/or the race pipe, it looks like the plastic T's in there are replaced by 90* elbows...does anyone know where these can be sourced at for the 3mm hose?
Thanks!
flee
Chatsworth, CA
2002 Jetta GLS wagon
Thanks!
Never thought to cap the solenoids but it couldn't hurt.
Vacuum connectors can be found at your local auto parts store.
Remember that 3mm is just a smidge smaller than 1/8" so any elbow that size would work.
Lastly, the diagram has elbows shown but you need not slavishly duplicate that detail.
Simple straight connectors should suffice. ;)
