phantom1260
Just picked this up last week. Starts, Runs, and Stops surprisingly well. Paint is in good condition given the age. Few rust bubbles here and there.
It has some rodent damage. Speed Sensor wiring is chewed up, as a result the Speedo does not work nor the odometer. Tach, Temp and Fuel gauge work. Although the fuel gauge will move when going through turns etc.
Then there's the larger I believe 28 pin round connecter it's referred to. That has a few wires chewed out as well but I'm not sure what those are for. The temp gauge seems to operating correctly so I guess I can omit that. What else does this connect to? I see some wire going to the pump but I though that was all mechanical so not sure what those are for. I believe it also connects to the oil pressure sensor. I do get the oil pressure light on the dash for 2 seconds after starting but then it goes away.
Don't have timing belt history so will be getting that done next week sometime.
Previous owner said it needed a clutch and battery. For me both the clutch and battery have not caused me any issues over the last week.
List of other issues below.
Airbag light is on.
Radio does not work - lights up green but buttons do not work. Just has a burned in display that does not change.
Cruise does not work - probably related to the speed sensor wiring missing
Front Indicator light stays solid when lights are turned on. Right side bulb is missing - I'm told this is probably a bad ground.
Rear indicators flash fast - Possibly due to the front right bulb missing.
Washer fluid tank has a leak
Bumper needs to be reattached from right side
Rear left door handle and lock assembly is disassembled
Airbag light is on.
