Victor-Whiskey
I did my first oil change yesterday (7850 mi). I put it on ramps to do get underneath. I noticed that with the car tilted back on the ramps, it appeared there was a portion of the oil pan that doesn't drain. I have a rotating flexible tube camera used for airframe inspections. So, because I am a nerdy engineer type, and to check this and the oil pan, I inserted in the oil drain after it stopped dripping. On either side of the drain plug was ~1/8-1/4 qts of oil. My suspicions were correct. I used a hand pump siphon to get it out. I believe it would drain completely if level. This could also account for those who posted they needed slightly less oil during changes.
Just keep this in mind if using ramps for oil changes.
