MattCrawford
Hi, new to the forum here, but I have a '03 Jetta TDI and want to know if I can use biodiesel fuel? If so, where does one get it? Thanks.
Matt
Matt
How do you do that? What additives are out there and where do you find them?If your climate dips below 32F...you'll need to winterize B100.
Power Service Diesel Fuel Supplement (DFS...@ Walmart in the "White Bottle") is one such supplement. What I did last winter was blend with winterized, retail petroleum diesel (yuch! hated every drop I had to mix in).How do you do that? What additives are out there and where do you find them?If your climate dips below 32F...you'll need to winterize B100.
Probably one of the better additives is by PowerService and is call Artic Express Biodiesel Anti-gel.How do you do that? What additives are out there and where do you find them?If your climate dips below 32F...you'll need to winterize B100.
So any winter diesel treatment will work? I thought you might have to use a special BD treatment for B100.Power Service Diesel Fuel Supplement (DFS...@ Walmart in the "White Bottle") is one such supplement. What I did last winter was blend with winterized, retail petroleum diesel (yuch! hated every drop I had to mix in).
I experimented with both DFS and the BD Anti-gel from PS last winter. PS had told me that the two formulations were "similar" but not absolutely identical. I found that DFS seemed to work about as well and was commonly available (I couldn't find ANY retail source for the BD anti-gel). PS actually sent me a small bottle for my tests.Probably one of the better additives is by PowerService and is call Artic Express Biodiesel Anti-gel.
