I thought I'd start a new thread similar to the features/easter egg thread, but specific to information that gearheads and techies would find interesting.
For example, while changing the oil yesterday, I noticed that the A/C compressor has what appears to be a servo attached to the back. If it is, then this is probably a variable-compression ratio compressor -- meaning the compressor adjusts to the required cooling load instead of (the old way) cycling on/off. [OR - this could just be a new type of clutch...]
Another example: What is the electronic device situated in one of the fuel lines (near the oil filter); Is it a sensor of some sort?
