Abacus
That helpful B4 guy
It is not me, I am just putting out the request. There is someone on Facebook I've been conversing with to try and get him up and going. He is off a rest area on I-77 around Charlotte and he lost the throttle response on his '97 B4.
I've been on the phone with him for the last hour but he needs someone local to help him out, preferably with a VCDS.
So far we have tried:
* diagnosing the ECU ground under the boot going to the ECU
* ECU connection itself
* black brake switch is functioning normally, blue did not change but we can't tell if it's working
* very minor split on one of the 3rd injector wires, but IMHO not enough to cause an issue
* engine grounds are fine with no chafing or corrosion
* actuated/snapped the brake pedal and throttle pedal with the hopes it'd jar something if there was a loose connection
He is from NY and was traveling north when the car acted weird and bucked. He pulled over and shut it off, then restarted it. It starts fine but idles at 1,200 rpm's and the glow plug light is flashing.
I did a search on here and went through what I could find for posts but did not find anything that helped.
He has no tools and the rest area is of no help, no scan tools either.
Can anyone help him out? Since he posted his number openly on Facebook (on the "VW Diesel TDI IDI and mTDI support group by VWDiesel.net"), I will post it here temporarily and will take it down when he's on his way again.
(845) 258-zero976 and his name is Ben. Nice guy to talk to but he really needs a hand.
