dustingebhardt
I'm knee deep into a clutch and slave cylinder replacement. My contact surface of the flywheel feels loose. With gentle pressure I can push it in towards the motor by about 2-4 mm. I can wobble the disc edges so that they make contact with the toothed flywheel plate, which is about 5mm. I know that it isn't supposed to move radially more than a few millimeters, which is doesn't, so I assume that the springs are still good. Should I replace the flywheel?
