dieseldonato
Hi all, just picked up a very clean 01 jetta with the alh engine. Till I had kids I was a over the road heavy duty diesel mechanic, so not new to diesels. I'm a 5.9L cummins nut and find myself a bit out of my depth with what all this little engine can take before going internal. id really like to get up around the 200hp mark, but currently im in the middle of building a new shop, so pulling the engine is gonna be out of the question for a while. the timing belt and water pump were done about 2 years ago by a vw shop,(not a dealer) they supposedly replaced the clutch as well. i wasnt told the brand, but the guy i bought it from said it was a better quality then stock. whatever that means. im basically not looking to buy twice and id really rather drive it like a turd then have to get parts a second time. so here goes. is a main girdle needed to get to the 200hp mark? i plan on head studs and possibly main studs whenever it gets pulled to put a known good clutch and a single mass flywheel. at that time the head will come off as well so i can inspect the engine and replace the head gasket. depending on what things look like i may consider changing rods, but if i can get close to 200hp and leve the stock rods alone, id be just fiine with that as well. im open to injector and turbo suggestions as well as a reputable tuner. id prefer a southbend clutch, ive worked with them a lot on different applications from pickup truck to pulling trucks and tractors. normally the guys that play with stuff have the insight as to what works best. planning on 2.5" exhaust and down pipe. i dont really know why larger would be needed for the modest hp goal i have. i mean i can take a cummins or powerstroke to 300hp before it becomes a restriction so 2.5" should be plenty for this thing.
im open to suggestions on about anything. more so want to start getting parts in and when my new shop is finished just be able to pull the car in and have at it.
thanks, sean
thanks, sean
