Upgraded Slave Cylinder
pipesta
Chicago, IL
'14 JSW TDi 6MT
My JSW has the dreaded dead clutch pedal. I bled the clutch a few weeks ago and it's dead again. I'm thinking it's the slave. I plan on a SBC Stage 2 clutch. I'd like to upgrade the hydraulics as well while it's apart. Does anyone have any experience with the Clutch Masters aluminum unit?
Mongler98
COLORADO (SE of Denver)
Have not had direct experiance with that kit or that company but it looks high quality. Not much to go wrong with AN fittings and aluminum block stuff.
Looks nice.
A bit pricy but you probably get what you pay for with this kit.
pipesta
Chicago, IL
'14 JSW TDi 6MT
Yea, the price is not for everyone. But I feel if it's quality and you don't have to worry about the stock plastic slave failing, it's probably worth it. And I like shiny things lol! Hoping someone had some real life experience with it.
arneeche
Oklahoma
2006 Jetta TDI (former), 2012 Jetta TDI (Former), 2014 JSW TDI
Did you end up going with the clutchmasters unit? If so how is it?
pipesta
Chicago, IL
'14 JSW TDi 6MT
Ordered it and sent it back. Build quality was top not but I was not able to shim it to the same spec as the stock slave. Apparently the gasser slaves are different. Ended up installing the all metal Sachs unit along with the aluminum bleeder block and braided hose from USP Motorsports.
