Upgraded fuel metering valve
Mrrogers1
Omaha NEEEBRASKA
2011 Golf TDI 6MT, 2011 Jetta TDI DSG, 2015 Golf Sportwagen S TDI DSG, 2010 JSW TDI 6MT
Curious to know because I was about to buy the kit for my car. I've heard things all over the place with every kit, its hard to say which is the better one to get.
Same here... what are the other kits (assuming you are talking fuel system saver) are floating around as I only knew about Whitbread.
McGuirk
Florida
Audi A3 TDI, 2012 Golf TDI , 2014 GTI to TDI swap
Fisher motorworks sells a kit that lets you install the bmw cp3 pump. Darkside also sells a kit. The Fisher kit is different than the white bread kit. The dark side kit looks like a copy of it.
Mrrogers1
Omaha NEEEBRASKA
I think (thought) he was talking about the fuel system saver (that's what I was talking about), not the CP3 kits. The CP3 kits are pretty much the same result, they all work good, fit and the big difference is the 2 different CP3 pumps used (the metering valves are specified and sometimes provided). The kits for the BMW R70 CP3 is the new kid on the block though, initial the R90 was the original version everyone had/has.
calimustang
Central FL
if I were you, get cp3 pump alone from ebay and get their mounting kit from those vendors. that way you don't need to get BMW CP3, get the actual CP3 gear driven unit that will not need you to keep the aux pump.
search for the cp3 on eBay, 0445010042 or
seller: nerings (I bought 2 from him in the past, no issues but watch for the FMV or have Malone tune it for the FMV model, that's what I did)
MrCypherr
Ontario
Mk6 Wagon
Thats a good idea. I know a couple of place I can get just the CP3 pump. I'll prob go that route. Still have some time before my next timing belt service.
calimustang
Central FL
indeed, you are welcome. I have been hearing about UK Diesels that sells cp3 pumps. several vendors including whitbread performance has been using them.
cheeseling
USA
2013 Jetta Sportwagen CJAA
Hey have you checked your fuel lines and how they’re flowing ? I had received a T fitting for fuel line plumbing and had the main flow of the fitting running to the inner roller of the fuel pump. After realizing this I switched the fitting to have the main flow entering the metering valve and it got rid of my limp mode issue. I was unable to floor it without getting limp mode and P0087 but now get thrown back in my chair in launch control with ease.
VW_Diesel_All_Day
Virginia
2013 Passat TDI, 2014 Sportwagen
Bumping this thread. I've been running the Whitbread Containment kit on a 2014 Sportwagen TDI CJAA DSG with Tunezilla "Stage 2.5"
I've been getting P0088 codes for Rail/System Pressure Too high both at coasting and when driving aggressively, especially once the car is fully warmed up.
I'm getting freeze frame data and a logging run for them.
Since the car has over 195k miles I started swapping some parts:
Downpipe
Stock CR140 Turbo (old turbo had minor shaft play)
EGR Cooler Removal and Coolant flush
O2 (Lambda) sensor
Primary EGT Sensor in the turbo manifold
N75 valve and all vacuum lines
2200-BAR Rail Pressure Sensor
MAF
Mann OE Air Filter
Liqui Moly Motor Flush and Oil change every 7000 miles or annually
DSG Service and Uprated DSG Heat Exchanger
Fuel filter changed every 14,000 miles (every other oil change or annually)
The Fuel Metering Valve, MAP sensor, and rail pressure relief valve are original. Valve cover and injectors are original. Timing was done at 131k miles.The intercooler was replaced under warranty about 2 years ago at 165k miles.
I'm planning to swap in the Kerma Boost hoses, CKRA intake manifold to remove the swirl flaps, EGR Valve Race Pipe, and new ASV/Regulating flap gasket. . Will probably do the thermostat housing and Serpentine Belt Tensioner then.
Don't worry, all the good parts are finding other homes!
Speedmaster_102
Southwestern Ontario, Canada
2014 Golf Sportwagen TDI
Downpipe
O2 (Lambda) sensor
MAF
Mann OE Air Filter
Any updates? I'm curious to know if it's Malones tune or the Whitbread kit.
1bad19d
Mobile, AL
2012 sportwagen 6-speed
BTW- I used Grok, which said the Bosch 03L906054A is the correct sensor which according to Bosch is rated for 2200 bar.
1bad19d
Mobile, AL
annnnddddd... TuneZilla says cascadegerman.com/product/2200-bar-cp3-fuel-pressure-rail-sensor-cbea-cjaa-ckra/?srsltid=AfmBOopZNazclCKZf4mlVyOaJKlNHYJxW7QBUpHNiPQwmMiV4nPd76S8
is the one they recommend.
Speedmaster_102
@VW_Diesel_All_Day
@Speedmaster_102
My Whitbread's CP3 kit arrives today, I have the tunezilla stage 2 as well... I am having trouble sourcing the 2200 bar sensor... any help would be appreciated. TIA
I bought a FEBI sensor from an eBay european reseller. The Febi part clearly is OE and it has the VW / Audi logo scratched out.
Febi part no # 102489
Here's a link from a reputable US seller: https://www.fcpeuro.com/products/vw-fuel-pressure-sensor-febi-102489
For clarification, this sensor is for the fuel rail.
